i need a radiator for my 23 track nose roadster. The with is 15" the height is 20".chevy hose hook ups both pass. Side . Any help i would buy a new one that is close and have it cut down but thats a waist.any help
Check your local radiator repair shops. They can usually get anything made. There's probably a supplier on here too.
I see you're in MI. If you're anywhere near Mt. Clemens check out Superior Radiator. Really good stuff, and reasonable.
call C&R racing Inc. 317-293-4100. Best radiators anywhere, everything from NASCAR, IRL, Sprintcars, Imports, and your car! lol you will not be dissapointed trust me I do the quality control! Ask for Devon. Bob
Absolutely without a doubt Devon at C&R Radiator will help you solve your problem. He is the most informed and has cutting edge technology. It won't be cheap but it will work without fail. If you need help Devon will stay with you and walk you through the fix. It may not be the least expensive but it will save you hours in the end.
Superior Radiator in Mt Clemens built me a custom one for my '47 Olds in 2002 and I've got over 116,000 miles on it since without any issues whats so ever. I would not hesitate to use them again.
