Projects quick change using model a banjo question
Discussion in 'The Hokey Ass Message Board' started by saints, May 16, 2011.
  1. saints
    saints
    Ive seen them and cant find them but the quick change center that uses the axle tubes and gears from your model a banjo it replaces just the center section?
    anyone know where I can find them and also it sounds like it may be alittle weak and I should go with a full quick change setup has anyone used these?
  2. saints
    saints
    its being powered by a stock 8ba if that helps
  3. Russ Gaylord Fontana
    from Home
  4. Dale Fairfax
    Dale Fairfax
    Halibrand nade a Model A quick change plus a V-8. The Model A was similar to the stock center section in that the pinion gear was supported only at the pinion shaft bearing. The V-8 model followed Ford design by incorporating a "straddle mount" which had an additional bearing inside the case. They both were designed to use stock axle trumpets and axles. I see the Model As at swap meets now and then-I believe they were often used in Midgets.
  5. brokenspoke
    brokenspoke
    There is a Model a QC and a midget QC....the change gears are different....The Model A QC is hard find, a Halibrand that is..Kiwi is a good one
  6. Rodsville should do the trick for you.
  7. kwmpa
    kwmpa
    from Pa
    I've seen a model a one at Hershey...not seen the kiwi one in person but have heard good things...the model a rears are a little weak behind flatheads but ive seen them work too...it's a toss up
  8. UPState Bill
    UPState Bill
    from New York
    Dick Spadaro has them for open or closed drivelines.Hes here on the Hamb
