235 babbit for 261 swap
Discussion in 'The Hokey Ass Message Board' started by Panhead Joe, Mar 24, 2011.
  1. Panhead Joe
    Panhead Joe
    I am going to be swapping the stock Babbit 235 from my 1952 Chevy Coupe with a 261. It is a Powerglide car.
    The swap seems pretty straight forward or am I missing something?
    Does anyone have advice or tips for me?
    Thanks
  2. IWB
    IWB
    Check with Patrick's he's in Az. 520-836-1117
  3. bmc
    bmc
    from Sacto.,Ca.
  4. Snarl
    Snarl
    what year is the 261?
    unless its a '54 or '55 first series engine, you will have motor mount and water pump issues when installing in a '52-54 car.
  5. Panhead Joe
    Panhead Joe
    I am not sure on the year. I will be picking the engine up next weekend and can check the casting numbers then.
  6. Panhead Joe
    Panhead Joe
    Picked the 261 up from a fellow HAMBER this weekend. The casting #'s on the block are 3733950, so I assume it is a 54.
    The Babbit 235 in the car now has a front motor mount and side mounts as well. The 261 doesn't have the holes for the side mounts. I see where they can be drilled and tapped. Is it necessary or is the front mount enough?
  7. Lotek_Racing
    Lotek_Racing
    Are you sure it's a babbit bearing 235?
    I thought sidemounts didn't start on the motors until 1958. If that's the case, it should be an insert bearing motor.
    Shawn
  8. Snarl
    Snarl
    '52-54 cars had a unique 3 bolt side mount that is different from the '58-62 design.
  9. Snarl
    Snarl
    There should just be the 3 bolt side mounts and a mount under the transmission on '52-54 cars.
    '52-551st series truck engines often did not drill and tap the 3 side bolts as the trucks didn't need them. They mounted under the timing chain cover.
    There should not be two sets of front mounts on your car. If you were to use the '49-51 style mounting off the front motor plate, then you will also need to add the '49-51 style side mounts on the bellhousing. Without these "training wheels" on it and just a mount under the front of the motor and under the trans, it will torque over too much.
  10. Panhead Joe
    Panhead Joe
    How can I tell if the Rochester on the engine is the original for 261 or if it is a 235 carb?
    Thanks to all for the other input.
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Measure the throttle bore. 235 carbs are 1 9/16, and 261 carbs are 1 3/4.
  12. Snarl
    Snarl
    my 261 carbs measured out to 1 11/16" bore...
  13. Panhead Joe
    Panhead Joe
    Mine measured at 1 11/16" bore
  14. Panhead Joe
    Panhead Joe
    Can I drill and tap the 3 spots on the 54' block to use the current side mounts in the car?
  15. Snarl
    Snarl
  16. Panhead Joe
    Panhead Joe
    Will I need to use a short shaft water pump?
