flatty carbs
Discussion in 'The Hokey Ass Message Board' started by kenbob26, Nov 4, 2010.
  1. kenbob26
    kenbob26
    what carbs should i run on my 50 flathead
  2. kenbob26
    kenbob26
    ok maybe i should say who has a good set of carbs?
  3. Saxon
    Saxon
    from MN
    So are you doing a dual set up?
    Holley 94's work as well.
  4. kenbob26
    kenbob26
    yes I have a couple of 94s on a offy intake but they dont match . mabe i should get some parts carbs or buy a new set of demons?
  5. uncle max
    uncle max
    Right here, right now... Two showstoppers. PM me.
  6. Doc.
    Doc.
    97's ....Uncle Max
    94's.....Dickster
    Done.
  7. There is a lot of good help here...
  8. dirty old man
    dirty old man
    Either way,you're gonna have to do something about that sorry ass "loadamatic" distributor when you go to dual carbs. The spark advance was awful when new and will be first class fucked up with the dual carbs.
    There's a guy on HAMB, "GMC Bubba" who can build you a distributor that will get the job done.
    Dave
  9. Shaggy
    Shaggy
    from Sultan, WA
    I'd go 94's, probably a matched set of ones that say 8ba on the side, that was what was on it stock, so why not stay with it???
  10. kenbob26
    kenbob26
    msd is what i have installed . I have a couple real nice stock distribitors.
  11. big bad john
    big bad john
    ..........Can't go wrong with the 97's.........
  12. dirty old man
    dirty old man
    Well, if you have a distributor from MSD you've got just about the best that can be bought for your application. Good move! The advance system on the OEMs was miserable stock, and adding another carb throws the vacuum signal so far off it won't advance properly.
  13. Mike51Merc
    Mike51Merc
    I think the Demons, although attractive in many ways, are just too big (by the pair) for a low-displacement low-flow flattie.
  14. carbking
    carbking
    While I like Stromberg EE-1 carbs (of which the "97" is one); Carters are a more up-to-date design, and much more infinately tuneable. Both the WD-0 (older) and WCD (newer) were produced in the 3 mounting bolt design.
    The extra tuneability can, depending on one's ability and access to parts:
    (A) be a major headache
    OR
    (B) produce better power, economy, and driveability throughout the entire RPM range.
    Like the Holley 94's, the Carters are somewhat larger physically than the Strombergs, and may not clear on all intake manifolds.
    Jon.
  15. strombergs97
    strombergs97
    Can't beat a pair of Stromberg 81s on a Flathead, small CFMs for small CIs...
    Duane.
  16. 19Fordy
    19Fordy
    Would a Mallory electronic distributor with mechanical advance work in place of the stock 8BA Load-A-Matic?
  17. 27willys
    27willys
    from indiana
    holley or stromberg I dont think you will go wrong. just make sure on either one you regulate the fuel pressure.
  18. kenbob26
    kenbob26
    my f100 runs 3 2100 series holleys (94s) four bolt base. I just need a good set up for the flatty strombergs would be cool . like i said a good set of carbs is what i need. lots of good help here thanks.
  19. dirty old man
    dirty old man
    Should work great, assuming it is in good shape. I have read that Mallory's quality control isn't what it once was, but what is, these days?
    Dave
  20. Redbows35panel
    Redbows35panel
    What are you trying to accomplish? There is a four barrel manifold for the flatty that really works well. Then put a Carter WCFB on it and get good performance all the way around without the head aches of dual carbs:cool:
  21. 19Fordy
    19Fordy
    Thanks for the reply. I bought the Mallory about 10 years ago so maybe it's one of the good ones.
  22. kenbob26
    kenbob26
    I just got my car back and it is still intact. carbs are still there. I am still thinking about 97s although they are a bit pricey . here is a pic of the engine in my 50 ford as of today.
  23. Mr. Clean
    Mr. Clean
    I have ran the Mallory Electronic distributor with 3 Stromberg 97's for the past ten years on my 49 coupe without any major issues. This is a good combination.
