Altered Wheelbase 59 StudeBaker Lark Build Thread
Discussion in 'The Hokey Ass Message Board' started by gasser55, Sep 25, 2010.
  1. gasser55
    gasser55
    I bought this car for cheap awhile back and started to collect parts to build it. The engine will be set back 17% with a 15" altered wheelbase front wheelbase was moved forward 1 1/2"
    Heres what I started with
    [​IMG] [​IMG]
    After engine and tranny was pulled out I set the sbc mock up engine and four speed tranny in the firewall
    [​IMG] [​IMG]
    After fabbing the engine mounts I cut the firewall to make room for the cross ram intake and started to make my fender well exit headers
    [​IMG] [​IMG]
  2. gasser55
    gasser55
    I cut the front of the frame off and made new frame rail to install a willys front axel I machined out to accept 40 ford spindals
    [​IMG] [​IMG] [​IMG] [​IMG]
  3. gasser55
    gasser55
    I worked on the tilt setup for the front end and moon tank placement.........I made a slide/tilt for the front
  4. studemisfit
    studemisfit
    Not a hugh sbc guy but i think you work is awesome. Keep the pic's coming.
  5. gasser55
    gasser55
    New bushings were pressed and the king pins fitted I was able to roll it out of the shop
  6. gasser55
    gasser55
    Next rear inner wheel wells and floor section was removed for the rear alter
    [​IMG] [​IMG]
    outer quarter panels were cut and Body was lifted of the chassis
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  7. flatheadpete
    flatheadpete
    from Burton, MI
    Pretty bad ass.
  8. gasser55
    gasser55
    After the chassis was removed I cut 15" out of the frame
    IMG]http://i202.photobucket.com/albums/aa22/gasser-55/017-3.jpg[/IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  9. gasser55
    gasser55
    Chassis was cleaned and set back under the body
  10. Ruiner
    Ruiner
    Wow, those headers are about as untuned as you can get...you're definitely not concerned about performance, are you?...the fab work seems pretty good though, and I dig the tilt frontend...
  11. gasser55
    gasser55
    Heres some pics of the quater panels being filled in
    The under side of the trunk drilled out
  12. storm king
    storm king
    May as well put a steering brake in it; with that much setback and that much wheelbase alteration, it's just going to be a wheelie car...
  13. gasser55
    gasser55
    This is going to be a car that I can drive to the track /car shows and drive it back home........... i'm working on the roll cage this week and will post pics as I go.
  14. newsomtravis
    newsomtravis
    from pville, ca
    awesome car, but are you sure those are fenderwell headers and not like firewall or door exit headers......hahahaha.......very nice work
  15. gasser55
    gasser55
    I'm aware the headers are not equal length and they the will get swaped out for a nicer set later. my main concern right now is getting it drivable......And yes i'm concerned about performance
  16. Onemansjunk
    Onemansjunk
    from Modesto,CA
    I can find only one problem with your build----------It Ain't mine!!!!!!!!!Sweet
  17. Drive Em
    Drive Em
    Awesome project. It takes a real man to cut one up like you did.
  18. Saxxon
    Saxxon
    This thing is bad-ass
    I'm a big dare to be different kind of guy and this certainly falls into that category
  19. OahuEli
    OahuEli
    from Hawaii
    Can I drive it? I promise not to turn over 8000 rpm.
  20. gasser55
    gasser55
    Heres the engine I built for it..........327 bored 30 over (331 cubic inch) venolia 13.5 to 1 pistons,steel crank, h-beam rods, ported and polished fuelie heads,under cut racing valves, solid lifter camshaft, windage tray, the intake is a edelbrock cross ram that will have 660 center squirters bolted to it, ronco magneto
  21. flatheadpete
    flatheadpete
    from Burton, MI
    Wheelies on the street....
  22. Stude-sled
    Stude-sled
    Love it!!!!!!!!!!!!!!!!!!!!!!!!!
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    WOW! by far my favorite buildup on the HAMB right now! cant wait to see more progress
  24. Hdonlybob
    Hdonlybob
    Very Very impressive.
    That will be a real headturner, and not your normal looking gasser either....
    Hurry up and finish....
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
  26. deucegasser
    deucegasser
    Pretty wild. I dig it!
  27. teddisnoke
    teddisnoke
    from So Cal
    Great stuff coming from that hanger of yours. Guys- deucegasser built the Stick City Comet if I'm not mistaken, and if you've seen that car you know what he's capable of pulling off!!!
    Can't wait to see this one done!
    Dale
  28. gasser55
    gasser55
    The 65 comet I built dales talking about......
  29. ramzoom
    ramzoom
    You mean this one........
    Yes, Mike (Gasser55) built that car...
    He can actually build some cool stuff when hes not working on Ramblers! lol..
  30. ramzoom
    ramzoom
    Looks like Mike beat me to it!
