I have a couple of freshly chromed bumpers for my '59. I need to put them away until I get it running. Should I put them in plastic bags?
Apply a good coat of car wax but don't rub it off. Then wrap them up in blankets real good. Then put in plastic bags if you can. Then store them inside - under your bed. Oh, also write down somewhere where you stored them.
Mine came back from the chrome plater wrapped in brown paper. I stuck them under the bed just like that for over 5 years before they went on Big Olds. They were just like the day I picked them up when I unwrapped them.
Plastic bags will just trap moisture, put them up in the rafters of the garage with a blanket or towel over them to keep the dust off them.
I would get some CRC SP-400 [in a spray can] most likely find it at an industrial supply store..Plastic bagging after coating probably wouldn't hurt but where you are going to store them is important, got to be dry, low humidity..got room under yer bed?
I agree with the coat of wax,my buddy use to store cars in his unheated pole barn with dirt floors and all for people and a guy stored a Model A in there for a winter and put wax on all his chrome before he stored it,spring time came he pulled it out and removed the wax and she was good to go!
There we go, I wrap my chrome parts with 4 sheets of newspaper. I bought a pair of chrome hood hinges from my friend and they were sitting for about 2 years wrapped in newspaper and when I opened it to check it out, the chrome was fine, no oxidation. Bottom line, newspaper works.
I bought a car once and one of the Seller's main selling points were the "perfect" chrome bumpers he had done several years previously and had stored wrapped in plastic in his garage's loft. He got them down and unwrapped them for me - I thought he was going to cry. Little rust spots all over them. The looked like they had measles.
thanks I just put a coat of wax on them & wrapped them in newspaper. They should be ok in the rafters now. Glad I posted this question, you guys are the best..
