Features my first custom...'49 ford tudor
Discussion in 'The Hokey Ass Message Board' started by 2345.coupe, Sep 13, 2009.
  1. rodknocker
    rodknocker
    Thanks a lot for posting you build,its going to help a lot of people.You're doing an excellent job.
  2. big creep
    big creep
    fuck that must have taken forever! looks great!
  3. got a few floor patches done and started prepping the fire wall
  4. got a little more sanding done......most of the effort was in the front window channel....have to remove all the rust, treat it with rust preservatives and level it out so there no leaks
  5. patched all the holes in the floor I could find........
  6. a little more work left on the fire wall, then she'll be ready for the epoxy primer.....also got some sanding done.......
  7. Tony Ray
    Tony Ray
    listen man.. Im getting really tired of watching you working on your car.. I think its time you drop what your doing and start on mine.. great work keep it up!
  8. got some more sanding done.......
  9. Pinstriper40
    Pinstriper40
    Looks great! Isn't turning all the old paint to dust fun?
  10. tschmitt
    tschmitt
    from IL
    Looking good, keep up the great work!
  11. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    WOW, nice build. Checkout my shoebox project (My avatar).
  12. Stefan T
    Stefan T
    from Sweden
  13. a little more sanding done.....the last two pictures are for Pinstriper 40....the mound of paint dust is what the sander caught from the rear quarter.....
  14. Taff
    Taff
    great post
    I like what you did with the door catches, very novel. might have to pinch that idea as they are next on my list for my chevy.
    Also really likr the ivory wheels, nice change from hot rod red
  15. Bash'n'Weld
    Bash'n'Weld
    You should be happy that you don't have half a bucket of bog (bondo) dust as well!
    Lookin good.
  16. removed the old rotten lower back panel.....drilled out the spot welds, a little cutting and she came right out.......little more work and she'll be properly fitted....... a little adhesive cleaner to remove the stickers and it's good to go.....panel came from Mac's who got it from EMS
  17. passenger side sanded, 40 grit........
  18. O.Hove
    O.Hove
    from S.D.
    Those are Plymouth wheels
  19. Pinstriper40
    Pinstriper40
    Thanks for the dust pile pics! It sure is nice to get those days behind you, isn't it? Nice progress by the way!
  20. Pinstriper40
    Pinstriper40
    What are your color choices? I was thinking Maroon and ivory for my car... Is yours getting chopped eventually? You make me feel lazy... I'll get my floors done in the next week or two. Great Job so far- Feels good when a project cooks right along!
  21. Wicked50
    Wicked50
    Looking good keep up the good work
  22. CheapSheep
    CheapSheep
    Hope you're proud, 'cause you should be, with all that work!
  23. got back on the tudor.......got the tar and rust off half the inside firewall...getting ready to epoxy primer.......
  24. finished cleaning the inside section of the fire wall ,... the section under the windshield I sprayed with cold galvanized compound. It's loaded with zinc........prevents rust and corrosion.....
  25. big creep
    big creep
    nice! its coming alone well!
  26. Pinstriper40
    Pinstriper40
    I'm itchin' for an update...
  27. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Excellent! This car is moving right along, congrats and keep up the excellent work!
  28. the-rodster
    the-rodster
    I LOVE build threads!
    Great work.
    Keep us posted.
    Rich
  29. Jetpro
    Jetpro
    from Alaska
    Nice work! This post really shows how an old ride can be brought back to life with some dedication and sweat. Thanks for inspiring me!
  30. well it's been a little over a year, 13 months to be exact since I worked on the shoebox.....reason being ,I saw this '49 chevy 3100 I had to have....then I came across this great deal on this '52 IH L110 I couldn't pass up.......well ,the chev was "just throw a motor and trans in and drive,,hahaha....the IH was I'll work on that after I ....you know the drill.....I've been on the chev truck steady for a yr., in between I was on the IH.......
    now I'm back on the shoebox, re-prepping the fire wall , both sides, getting ready to epoxy primer it........changed motors...got a 302, roller c-4 combo.......hopefully I can keep my fuckas on the shoebox for awhile......
