Projects <<< NEW 1932 Ford Roadster Build thread, UPDATED 12/23/2009>>>
Discussion in 'The Hokey Ass Message Board' started by vendettaautofab, Dec 9, 2009.
  1. vendettaautofab
    vendettaautofab
    Rubbed my rear a little bit today... I dont know if it will be fully polished or not yet, probably just painted with the edges of the ribs polished.
    Hoping to get a chance to get this thing rolling in the next 2 weeks, we'll see
  2. cretin
    cretin
    Looks like a cool build! I dig the details such as the pockets for the end of the hairpin and the shock bell cranks. Should be a cool build to watch.
  3. flatliner32
    flatliner32
    from Indiana
    really Sweet Mike..........Like that the dog feels right at home,,,,Is he adding creative Ideas too?
  4. vendettaautofab
    vendettaautofab
    Thanks, I hope it all turns out...
    Thanks Doug... Lou dog is the driving force behind alot of the ideas through out the shop, but he's best known for his accounting skills...
    You ought to post some pics of that roadster of yours!
  5. MichiganJames
    MichiganJames
    Looks amazing, nice quality
  6. sr
    sr
    from Monterey
    So the one inch change in rail height at the center line of the axle will create the need for a shorter radiator, grille and modified hood sides etc. right? Or will it just take up the space that is usually between the stock hood sides and the frame rails when the fenders are not used on a high boy? Just trying to think about the frame change and what affect that will have on the other parts. I am curious to see how it all works out. Good job and thanks for sharing the progress and photos. I love to see someone elses builds, it always gives me new ideas.
    Also how did yo determine your pedal locations? Besides the stock settings? Just curious.
  7. vendettaautofab
    vendettaautofab
    Thank you!
    Thanks James, where in Michigan?
    The frame change in the front will create a bit of work, making the hood, sides, grille line up. The radiator will be addressed a bit in the crossmember location, as that will be moved back slightly to allow the axle to tuck up behind the chin of the grille shell in the "spring behind" type setup. Also, I plan on running a 2" shortened radiator, maybe even a non 32 radiator to get the lower neck in the right location all together to accomodate for the inboard shocks etc.
    Thanks for your interest!
    As for the pedal location. Thats a measurement that we have established on all of our frames. I dont recall it off hand, but if you call me at the shop, or email me, I can get it for you. Most all pedal manufacturers will provide you with that info when you purhcase the pedal assembly... I use primarly Pete and Jakes pedals.
  8. vendettaautofab
    vendettaautofab
    Few more...
    The car will have coilovers in the rear, complete with our fancy little covers, as pictured... I didnt want a tube rear crossmember, just didnt... no real reason, they work fine, just didnt want one on this from. I wanted something simple, that was strong and looked like it belonged. Made this 3/16" thick channel... matches angle on rails. Was going to drill holes, or emboss an oval... then decided to just leave it, keep it simple.
      31.6 KB
      41.3 KB
      45.3 KB
      134.8 KB
      147 KB
  9. vendettaautofab
    vendettaautofab
    The rear frame rails, as you see in the picture, will be bobbed... I didnt want to mark where until I set the body on the frame and such. The end of the boxing plates needed to be extended to accomodate the new crossmember... The ends of the boxing plates are a little crude as of right now, just because, they will be trimmed and capped.
    Before and after
      128.7 KB
      170.3 KB
  10. vendettaautofab
    vendettaautofab
    Crossmember contoured and tacked in place...
  11. vendettaautofab
    vendettaautofab
    Nothing fancy here, just Model A front crossmember, placed 1/2" back from stock, to accomodate the spring behind setup and allow axle to tuck up behind grill shell's chin.
    There will end up being a slight c-notch for both axle and spring... front of rails will get enclosed and the vallance will fill in between.
      160.7 KB
  12. vendettaautofab
    vendettaautofab
    Needed the fixture for a couple other frame builds, wanted to get mine out and check a few things, work on other components of the build, such as wheels and rear.
    Sanded the body up and sat it on the frame. This height is close to where it will be riding...
  13. vendettaautofab
    vendettaautofab
    Last couple for tonight...
      172.3 KB
      156.3 KB
      162.9 KB
  14. langy
    langy
    All looking good, I like the rear x member, simple and clean and ties in nicely.
  15. vendettaautofab
    vendettaautofab
    Thanks Langy... heres a couple more...
    Thanks goes to Tab at Diamond Back Tires for the Blackwall SMOOTHIES... great service and they look fantastic.
      168.7 KB
      196.7 KB
      207.4 KB
      157.4 KB
  16. vendettaautofab
    vendettaautofab
    Got the new Brookville roadster dash in, a little better than the flat dash. A fellow hamber is helping me out with getting the insert programed and machined. I cant remember his hamb name, but I can turn you on to his phone and email if you need any CNC work, he is from east side of the state.
  17. langy
    langy
    I reckon that dash insert is gonna look very trick :) I assume the front splash pan will echo the trim ???
  18. straykatkustoms
    straykatkustoms
    Whooa!! Thanks for letting us peak at your project. Jimmy Smith koncept drawing
    is killer makes me want a '32 roadster even more. I'm looking forward to watchin the
    build process. Good luck.
    Happy Trails,
    Mick
  19. Lookin good Mike
    Ya gonna use a Rodwell windsheild?
  20. bustedwrench
    bustedwrench
    OUTSTANDING. From the concept art to your work on the car itself,that is some fantastic workmanship.Really raises the bar a notch or two.
  21. vendettaautofab
    vendettaautofab
    The front splash will have the same feel, as will the rear valance.... all very much like the final drawings. The "ribbed" theme...
    Thanks again Langy for the kudos
    Mr. Smith is a master, and having the drawings helps more than you can imagine in the build process. Thanks for the kind words.
    Thanks Don... no Rodwell... I will be using a stock style frame, chopped 3" and my own stanchions
    Thank you!
  22. hot rod pro
    hot rod pro
    from spring tx.
    looking real nice. keep us posted.
    -danny
  23. PeteFromTexas
    PeteFromTexas
    Very nice. Watching this build very close.
  24. claymore
    claymore
    This is like the HAMB soap operas for guys... can't wait until the next day to see what you have accomplished overnight. Good stuff.
  25. vendettaautofab
    vendettaautofab
    Thanks Danny, I appreciate your support
    Thank you, see you work for Hatfield's, nice stuff there as well!
    Thanks, no updates for a while... have a few other things to take care of, but will have the suspension taking shape soon.
  26. ChromePlaterJosh
    ChromePlaterJosh
    I love the ribbed theme. It gives it some understated classiness; the kind of details seen on high-end cars of the era.
    I envy the skills in fabrication shown here.
    Good luck on the build!
  27. Gotzy
    Gotzy
    Yeah definitely a great start on this one. Drawings are cool and your cross member modification is a simple idea professionally done that us garage butchers always love to see. Keep up the detailed coverage to keep us little guys aspiring to do better!
    So has getting the exhaust up and out of the way made you consider running a belly pan?
  28. vendettaautofab
    vendettaautofab
    As of right now... no belly pan
    Thanks for your kind words though
  29. ocfab
    ocfab
    any update!
