Help! Frozen rusty hubs
Discussion in 'The Hokey Ass Message Board' started by Rat Bastard Mike, Sep 22, 2009.
  1. Rat Bastard Mike
    Rat Bastard Mike
    from WA
    I recently bought a 1928 Ford rolling chassis, only it don't roll. The spoked wheels are frozen to the hub. Can anyone offer some advice on the best way to free them up, so I don't mess anything up trying it the hard way? (hammer, crowbar, etc) Thanks...
  2. oneratfink57
    oneratfink57
    from Wisconsin
    lots of PB blaster and a hammer to the center of the hub if its metal to metal
    good luck:cool:
  3. try some heat, heat them and let them cool a few times that usually will bust them loose.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Are you trying to free WHEELS from the hubs or rear HUBS from the axles?
  5. Rat Bastard Mike
    Rat Bastard Mike
    from WA
    I'm trying to remove the wheels from the hubs
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    1. Remove the lug nuts.
    2. If you want to save the wheels or brake drums, don't beat them off with a hammer or pry them off with a crowbar. If you don't, do.
    3. Spray the wheel around the hub with PB Blaster off and on for a day or two or three.
    4. Tap...that is...tap...the wheel around the rim with a 3-5lb hammer. Tap the wheel in a like manner around the hub.
    5. It'll eventually come off if you have the patience, if not, draw back and whang away until it is mangled and flies off.
  7. Rat Bastard Mike
    Rat Bastard Mike
    from WA
    Ha ha, I hope I don't have to whang away! I'll try the PB Blaster, heat, and tapping.
  8. Shaggy
    Shaggy
    from Sultan, WA
    Drill out the lugs nuts and studs if all else fails, Model a brake stuff is damn near worthless anyway
  9. jville_hot_skater
    jville_hot_skater
    from jville
  10. Just beat it beat it beat it :D
  11. oneratfink57
    oneratfink57
    from Wisconsin
    key point. spray. leave for a few hours. SPRAY. leave for a few hours. SPRAY. leave for a few hours then beat ( and yes heat usually works)
