56 gmc 3/4 ton axles?
Discussion in 'The Hokey Ass Message Board' started by Ornery37, Jul 27, 2009.
  1. Ornery37
    Ornery37
    from Texas
    I have axles out of a 56 GMC pickup. was wondering how good the rear is? it has a cover on back and 3member comes out also.
    also where is a good place to get breaks for this?
  2. squirrel
    Sounds like the Chevy rearend used in 3/4 tons up thru the late 60s. not much available for gears....and its' been working hard all its life and probably pretty well worn out.
    You mean stock brake parts or adapting newer brakes?
  3. Chevy55
    Chevy55
    from Nebraska
    Should be an Eaton 10.5" ring gear. I think LMC Truck of Kansas sells wheel cylinders and brakes for this rear. Try your local parts house for grease seals and wheel cylinder kits they might have something.
  4. OldSub
    OldSub
    Three different sets of gears available, 4.10 that is somewhat rare, 4.57 that is likely what you have, and 5.14 which was an option in 3/4-tons and standard in 1-tons.
    LMC and Jim Carter seem to have the brake parts currently. Or at least they did until my buddy bought stuff a few weeks ago.
  5. Ornery37
    Ornery37
    from Texas
    Cool! thanks all!
