I've read that radial tires are killers of ball bearings.What roller bearings has anyone used with 53 sindles & hubs?
i have not done it my self but a friend says just use early sixties drums complete with the bearings he did it on his 55
PM hawgrod at Shop #10.He should have the bearing numbers.He did a bearing conversion for me.He had to make a race to make it work.The bearings were in the $100.00+ range plus making a race.
That's a new one to me. I have quite a lot of experience with them and never had a bearing fail that I repacked. It's my opinion that if you repack them about every ten thousand miles and set them up right, not too tight/not too loose they work good and last a long time.
My 55 Chev Truck ran with large radials and a big offset for over 20 years without any problem. Although I wouldn't run the same offset today, it didn't cause me any problems even when carrying an 8ft camper. The load on the front end also included the extra weight of a 396. Bob
