Look another '49 Chevy build! What has been done so far: -Cut down a 123" wheelbase s-10 chassis to 118" -Mounted the cab to the chassis using Clark's method - thanks Clark! -Moved the "bottom" of the bed up 3" to lower the bed - thanks Clark! -Swapped a Blazer disc brake rear end under the truck Things to do: 1) Decide on engine/transmission - a. 235 w/T5 b. 350 w/700R4 2) Mount the bed 3) Mount fenders/radiator support 4) Mount the running boards 5) Only everything else.... '40PlyCoupe
Looks a solid truck to start with. I went with a 350/350 combo in my 53 GMC panel, mainly because that is what I could get quickly. Hope you get it on the road quicker than my truck is!
I REALLY want to put the 235 in the truck. However, the 235 is so tall it looks like the crossmember will be a problem. Does anyone know if a 235 will fit this swap? Truck update: Still working on the bed mounting Next up: Mounting front clip to chassis and then trial fitting the engine/transmission
Added a few new pictures of the build. It's not going fast, wish it could, but it's a lot of fun and things are moving ahead. Picked up a GM crate engine out of a van for $50, rebuilt 350 trans for $200 and mounted the bed. Still working on some steering, brake and header clearance issues. Love all the other build pics from others on this site, been a big help to my build. '40PlyCoupe
Looks like you got a nice solid truck. I'm doing the s10 swap also. Why did you go to a 118" wheel base? Keep the pics and progress updates comin'.
looks good!! i am doing a 49 on a s10 frame also. i went with a 327 and a Turbo 350.how are you going to tackle the radiator support?
Me too! 350/350 combos are more readily available 'over here'. Remember Swede...Rome wasn't built in a day,at least that's what I keep telling myself! (4 years into build)
I'm shortening the stock radiator support about 3-4 inches and using a 19x22" aluminum radiator from Speedway.
I believe the 118" gets both wheels centered in the fenders. The stock wheelbase leaves the rear tires a bit too far forward...
