does anybody have any info on what type of front end this is? i think its a suicide but what does it use as suspension as only the axle is in front of the grill and not the spring? and how does it work? some more pictures of cars with this would also be helpful. thanks-kieran
The spring hangs from the wishbones behind the grille. If you look closely you can see the shackles... It's still "considered" a suicide front end.
Gona be fun when the chassis rail stops after a flat tire up front but the rest of the car keeps on going driving the steering column through the driver's chest while the sterring wheel cores him like an apple. OUCH, scrubline, if you please.
Or you could just have a telescoping column, so nothing to serous would happen. jeese such pessemists..
The builders have been on the board. One flat and you would wish you built the car otherwise. Ever skip stones across a pond?
