looking for ideas on 48 ford
Discussion in 'The Hokey Ass Message Board' started by 47studes, Aug 26, 2008.
  1. 47studes
    47studes
    ok my brother just picked up a 48 ford coupe and is looking for some ideas for a custom grille he has a 49 plymouth grille he might try to make work but if you have any ideas or pics let see them.
    thanks
  2. Sweats had a 50 Plymouth grill, still got it Eric? Another trick is a 42 hood.
  3. 47studes
    47studes
    cool any more pics
  4. Nelly
    Nelly
    I've got a 49 Plymouth grille & bumper on my 46 ford coupe. The grille fit perfectly, but the hood took some serious metal work. Len (ChopShop) did all the fabrication.
  5. Django
    Django
    from Chicago
    I have a '48 Olds grille for sale.
    I love the '49 Plymouth grille in '46-48 Fords. If I ever have another one, that is what I'm going to do. That looks killer Nelly.
  6. alumslot
    alumslot
    This is my 48. The Plymouth grilles do look good. Mine is a 51 Buick not too hard to do and a little different.
      108 KB
  7. Try a 46 Olds.
    No big deal hangin 1
  8. OshkoshRob
    OshkoshRob
    from Oshkosh
    50's style Buick grill.
  9. Cal-Paul
    Cal-Paul
    I'm glad this tread started 'cause i'm looking for ideas also for my 47
  10. Another trick- Turn the hood upside down.
    Build a can to tie the 2 side together, tack it in,then ya can cut out the center filler (leaving the 2 side still together)
    Cut a filler and weld it in to make a 1 piece hood.
    Then pie cut from the rear side @ 0 to 1 1/2 " in the front
    Pulls the snout down just right.
    Good luck
  11. 47studes
    47studes
    thanks guys, also any ideas on the rest of the car, whats som other cool mods
  12. Cal-Paul
    Cal-Paul
    I put a rear window from a 57 VW on my coupe,with a 4" chop it brought the rear into proportion
  13. 47studes
    47studes
    have any pics
  14. SlowandLow63
    SlowandLow63
    from Central NJ
    This is a '47 I just finished up for now. '50 Plym grill. Still up in the air about a bumper.
    47 ford likes this.
  15. 47studes
    47studes
    anyone else have any ideas
  16. Pinstriper40
    Pinstriper40
    Here's the olds grille and later olds headlight treatments that I really like- stolen from the HAMB itself! If you can chop yours like the '41 you've got it made...
  17. Cal-Paul
    Cal-Paul
    work still in progress
  18. Chad s
    Chad s
    Heres my 47 with a 48 cadillac grill
  19. 47studes
    47studes
    alright good stuff here guys what else do you have
  20. I got me one of those 'glass chins from Fairlane, no bumpers, will be chrome pushbars, the bottom radiator splash panel I made after this pic came from a mid 80's Lincoln, might not be the right shape for the 49 Plymouth grill...
  21. Cal-Paul
    Cal-Paul
    I like the caddy grill.....how hard was it to put on???
  22. 'Mo
    'Mo
    If you're handy with sheet metal, the stock grill can be made more distinctive by removal of the top bar.
  23. 47studes
    47studes
    thanks for the great ideas keepem coming
  24. How about whackin the top off, chop the windsheild 4 1/2" and pull it back , suicide the doors,shorten the decklid 12"pie cut the fenders,hammer weld out the bodylines on all 4 fenders?
  25. Chad s
    Chad s
    Well, it was far from a drop in replacement. I first cut away any sheet metal that would allow the grill to sit in place for basic mock up. I then framed the grill in 1/4" steel rod, and fabricated the bolt on points to the grill from the 1/4" rod frame. From there I made the grill surround from 6 separate pieces, formed with a planishing hammer, and then gas/hammer welded it all together. I probably spent 3-4 weekends on the basic rough in.
  26. Lono
    Lono
    One of the best grills I've seen installed outside a stock 41! Looks good on you!
  27. Lono
    Lono
    pix man... pix!!!
  28. Ok, this is definately not HAMB traditional but the chop part is great. Work was performed by Fred Golden and Ramsey Mosley. If you are using IE you can enlarge the page enough to read the whole artical. I did this feature back in early 2002 or late 2001. Enjoy
  29. Was maybe planing to modify and use these lights in the front of my 41 Ford Tudor
  30. ken1939
    ken1939
    Must admit the Plymouth grill looks the nicest. Followed close by the olds.
