How can you tell the differance between a 292 and a 312 ? I have a 60 ford f100 and really dont know much about the motor but its supposed to be rebuilt. Thanks already .
Here's the best place for that info:http://www.ford-y-block.com/techincal.htm 1960 should of had a 292 but that doesn't mean anything this many years later, find the block numbers, certain blocks have better chances of being a 312(but all still could be a 292)
There should be a marking aroung the distributor The engine in my Fairlane was mistaken for a 312 because a 312 manifold was installed at some point - My tuneup guy pointed it out that it was actually a 292.
Dirty2, call Ted Eaton, he's near Waco, and a Y-Block guru. Super nice guy, will talk your ear off about them, full of information. I called him on a whim on a Sunday afternoon and he blew me away with information. My 292 will be sent to him shortly for some magic. Ted Eaton (254)857-3339 [email protected] www.eatonbalancing.com 1060 Wolf Creek Rd., Lorena Tx, 76655
From what I remember, you have to drop the pan and check the main caps. Look for it on Mummert's site. I was told my 292 was a 312 - just sweetened the deal to me. Of course it was a 292. I guess the 292 makes a better block when you bore it out. The 312 often suffers from cracks.
What got me to thinking was that it has a 4 bbl on it . But I'm not a ford guy. But things can change . Thanks for all the help. And I will be calling Ted .
312 has bigger mains than 292, there was trouble with pulling threads in the 312 blocks when torqued down because of less material in the main area after enlarging the main diameter. Ford's solution was lower torque numbers for the mains, what people are doing now is using 312 cranks and having mains and rear oil seal area turned down to 292 size and use in 292 block.
Danny, Look at John Mummert's site, lots of good info there and look un tech section, has way to identify the 312 crank by marking on back end of crank http://www.ford-y-block.com/yblockpage.htm
