Technical 1932 heavy vs 33-36 axle
Discussion in 'The Hokey Ass Message Board' started by Cody49Ford, Aug 11, 2025 at 11:09 PM.
  1. Cody49Ford
    Cody49Ford
    I’ve read a few threads, but trying to correctly id a front axle
    From the measurements I’ve found they appear to be the same for 32 heavy and the 33-36? Can anyone help ID this one?
  2. Dirty Dug
    Dirty Dug
    The one you have is a 33 to '36.
    Carter likes this.
  3. rusty valley
    rusty valley
    Your 1st pic shows it all, on that axle (33-36) the flat boss for the spring perch is higher than the beam.
    On a 32, the beam is higher than the boss
    RICH B and Deutscher like this.
  4. End of a '32 axle in comparison to your '33-'36 axle. Note the axle is taller than the perch boss as previously mentioned along with the distinct shape of the end and beam.
  5. Cody49Ford
    Cody49Ford
  6. alchemy
    alchemy
    Now that you can tell the difference, here’s a tip to make you look even smarter. Just call the 32 axle a 32 axle. No need to call it heavy. There is no light 32 axle. It’s kinda like when newbies call a Model A coupe a 5-window, when there is no 3-window.
  7. clem
    clem
    Cody49Ford likes this.
  8. Zax
    Zax
    1. 1952-59 Ford Social Group
    Wait, there is only one 32 front axle? I have always been told there was a standard used on the model Bs and a heavy used on the V8s.
    Wow, learned something new today
    porkshop likes this.
  9. clem
    clem
    There has been extensive discussion on this forum about this……..
    https://www.jalopyjournal.com/forum/threads/did-all-32s-have-heavy-front-axles.1082440/
    Here in New Zealand, the model B’s all seemed to have light axles and the V8’s had the heavy. (they all came from Canada).
    Seems to be the case in some European countries also.
  10. alchemy
    alchemy
    My early production B came with the real 32 axle from the factory (see I didn’t call it a heavy). I was the first guy to remove it from the car.
    After 32, when a car needed an axle replaced, the mechanic just walked to the shelf and picked up the 33-36 style cause it fits in the exact same spot.
    Pete Eastwood, Fordors and porkshop like this.
  11. Cody49Ford
    Cody49Ford
    Haha the 5 window sayings my favorite, I thought If I said heavy it made me cooler though. Good tip , I’ll get back to you after I check thye dizzy in my 1929 5 window with a flatty
    lurker mick likes this.
  12. 1946caddy
    1946caddy
    from washington
    No 3 window model A coupes, really.
    I've seen a picture of one. I believe the caption said that it belonged to Edsel Ford.
    Model A Ford Garage ~ Prototype Three Window Coupes
  13. alchemy
    alchemy
    How many rolled off the assembly line?
    RICH B, lake_harley and silent rick like this.
  14. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Used lots of 32 HEAVY axles. Nothing compares to 32 HEAVY dropped Greg Haynes/Anson Axles.
  15. DDDenny
    Ruh Row, not the dreaded Model A three window debate!
  16. Pete Eastwood
    Pete Eastwood
    from california
    Truth . . .
    rusty valley and RICH B like this.
  17. Back when you could find '32's in the junk yards I don't remember ever seeing one that didn't have a '32 axle; same with '32 frame hay wagons at farm auctions.
    lurker mick and Deutscher like this.
