Technical Metal forming a core support - advice needed
Discussion in 'The Hokey Ass Message Board' started by Chickenlegs, Aug 13, 2025 at 6:10 AM.
  1. Chickenlegs
    Chickenlegs
    I’m in the process of rebuilding the bottom of my core support (18 ga) on my 60 Ranch Wagon and debating on building it in plate form then bending, welding versus trying to form/shrink the metal into shape. I’m confident with the plate/welding approach but I’ve never tried to shrink that much material to produce a shape. The last pic is the stiffener (14 ga) that I produced with the plate/welding approach. Any thoughts are appreciated.
  2. SS327
    SS327
    A man’s got to do what a man’s got to do.
    It’s good to know your limitations.
  3. Could bend it straight in a sheet metal brake
    then cut it to form the shape. I’ve done that with rain gutters for trunks before.
    Saves a good bit of welding.
    I’ve also beat metal into submission before to make parts like that.
    2 halves and an end
  4. Happydaze
    Happydaze
    At 18 gauge I'd be a little concerned that the grinding of the welds to make it look pretty / factory might run the risk of grinding away the strength. Possibly increase to 16? Your 14g fabrication looks well. And agreed on the folded sections. Doable with no special tools.
    Chris
  5. Where about along the Warrior River
    I’m a central bama resident
  6. 5window
    5window
    I lived in Loachapoka for four years!
  7. bill gruendeman
    bill gruendeman
    Have you tried hammer forming? Make the form out of mdf (medium density fiber board), using a hammer work the metal around the corner. Look it up on here or you tube.
  8. Chickenlegs
    Chickenlegs
    I'm on the little warrior, just across from Miller steam plant.
  9. Dang
    That’s close
    I’m on county line in Sumiton
  10. gene-koning
    gene-koning
    Anthony can teach you a lot better then I could try to explain it to you.
    Please post pictures of the process!
    anthony myrick likes this.
