Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    Is this an all out top performance and need equal length?
    Can you siamese the center tubes to buy some room?
    mad mikey, osage orange and Sharpone like this.
  2. patsurf
    patsurf
    iron oxide for fertilizer!
  3. Sharpone
    Sharpone
    No just a fun car for now I’ll be lucky to get 300 hp if I add a cam, maybe 250 now. Down the road I’ll go 360 maybe stroked with roller cam, then I’ll for sure need a good exhaust to get 400- 450 hp. I plan on making Tri y s
    I think the 4 into1 on passenger side will fit no problem. Can a guy run a slightly restricted exhaust on one side or will this cause me problems?
    Dan
  4. Papaw has a log manifold on the drivers side from a 76 C-10, and a Rams Horn on the passenger side from a 72 C-10. Both with 2” outlets.
    chevy57dude and Sharpone like this.
  5. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Man, that car looks perfect as-is. :cool: I would have to just get it going and drive it. I can't imagine a frame off making it any more fun. :D
  6. saltflats
    saltflats
    from Missouri
    Got the trunk in primer, think this will be good enough for me. I will be spraying with some zolatone at a later date.
  7. RockyMtnWay
    RockyMtnWay
    Back from Deuce Days and decided to tackle my nit list on the Tudor.
    First up was the front floor.
    Was lazy when I did it, so didn’t put a surround in place around the shifter hole.
    Now it’s done.
    Also had some water sneak in from the front where floor meets firewall.
    Probably easier ways to solve, but I decided to weld some bigger splash guards on and do a better fit (for sealing) on the front corners.
    Now it’s off to get a layer of rhino liner like I did on the roadster floor.
    On to the next nit….
  8. Sharpone
    Sharpone
    saltflats and osage orange like this.
  9. Dick Stevens
    Dick Stevens
    Spatter paint, like the cars came with from the factory
    saltflats, osage orange and Sharpone like this.
  10. Sharpone
    Sharpone
    Thanks
    saltflats likes this.
  11. 49ratfink
    49ratfink
    I'm working on a Mickey's Big Mouth "Fine Malt Liquor". I'm thinking about working on my 49 Chevy, we'll see how well that thinking progresses.... been thinking I'm gonna have to sell it. I've owned it for 49 years.
  12. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    @Sharpone - Anything you do with your header experiment has got to be better than manifolds. Just my opinion, thinking about how manifolds were mostly designed to fit a space. The ones in your pics have the exhaust pulse at it's highest velocity hitting a hard wall right out of the port. Then totally unequal distances to the converging point. Your headers have a gradual sweeping turn, then a long tube. Hell, you can even start some bench racing folklore about tri Y / 4 into 1 header mixing..
  13. 51504bat
    51504bat
    Or the walls of a latrine in an Army barracks.:cool:
  14. impala4speed
    impala4speed
    I certainly hope you don’t have to sell your ‘49, especially after having owned it for that long.
  15. chevy57dude
    chevy57dude
    1. Maryland HAMBers
  16. Getting closer to a new color for the little Willys
    And today I picked up another set of fenderwell headers to try on the 57 pickup, if they do fit I'll have to figure out a collector for them.
    pila38, Okie Pete, mad mikey and 9 others like this.
  17. Scraped much grease and oil off of the 390 for Wifeys ‘62 T Bird.
    Then started unhooking stuffs to pull the motor out of the car.
  18. jeepster
    jeepster
    from wisconsin
  19. jeepster
    jeepster
    from wisconsin
    On to victim number 2, new race harness for the coupe. IMG_2537.jpeg image.jpg
    pila38, spudshaft, 41 coupe and 19 others like this.
  20. badgascoupe
    badgascoupe
    Back in N D for a month.Chasing dents in the 59 gmc , the Detroit diesel bolted in .Waiting on back ordered parts on the 61.
    pila38, Okie Pete, Robdski and 4 others like this.
  21. choptop4
    choptop4
    Might spray in the morning. Been in the 100s. 20250809_102230.jpg 20250809_102242.jpg 20250809_102652.jpg 20250811_094148.jpg
  22. Headers don't fit, this time around the passenger side doesn't clear !
    I'm going to have to pick the lesser of the evils and start modifying one of the 3 sets.
  23. Paul
    Paul
    Editor
    posted this elsewhere
    PXL_20250809_161128377.jpg PXL_20250809_161121940.jpg PXL_20250809_161412343.jpg PXL_20250809_161828045.jpg PXL_20250809_162120174.jpg
    pila38, Okie Pete, mad mikey and 13 others like this.
  24. Clydesdale
    Clydesdale
    As promised I managed to get the trim painted and on this week.
    It has a slight overlap on the front edge which I kinda like, it is an attempt at custom modifications after all. It’s also a little short at the back but doesn’t bother me.
    Please excuse my average job of fixing where an ornament had been mangled onto it and the ‘patina matching’ attempt with the paint.
    It’ll stay until I can get a better one and when I paint the car properly one day.
    For a zero buck modification I’m happy!
    pila38, 61Cruiser, lostn51 and 10 others like this.
  25. Sharpone
    Sharpone
    Looks good
    Dan
    chevy57dude likes this.
  26. partsdawg
    partsdawg
    from Minnesota
    Deciding what direction to go with these. Couple ideas marinating. IMG_0090.JPG IMG_0091.JPG IMG_0092.JPG IMG_0093.JPG
    pila38, swade41, brading and 2 others like this.
  27. BJR
    BJR
    Polish the aluminum.
    swade41 and Sharpone like this.
  28. choptop40
    choptop40
    Sharpone likes this.
  29. choptop40
    choptop40
    IMG_20250813_153032.jpg Borgeson quick ratio box...Real hotrods don't have power steering.....
  30. choptop4
    choptop4
    20250813_125520.jpg 20250813_125520.jpg 20250813_125548.jpg sprayed this morning. Came out just ok. You would never know i did this for a living in my miss spent youth.
    Cut and buff !
