Technical Heater install question
Discussion in 'The Hokey Ass Message Board' started by topher5150, Aug 9, 2025 at 10:36 AM.
  1. topher5150
    topher5150
    Looking at the coolant tubes on this heater should there be some kind of flare at the end? Also am I correct in assuming that it needs rubber grommets in the firewall
    Tow Truck Tom likes this.
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
    That's a Firestone heater. It's upside down in the pic. The tubes were straight, as shown, with no type of flare.
    I've found the defrost ducting (that's missing) is Hen's Teeth. A grommet goes into the flat support plates on the heater (one there and one missing). Grommets on the firewall are a good idea to prevent rubbing.
  3. RodStRace
    RodStRace
    And try to route the hoses as inlet below, outlet above so it burps air out.
  4. 41 GMC K-18
    41 GMC K-18
    B = Blunt
    U = Unscheduled
    R = Release "of "
    P = Pressure
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Also, some heaters of that era are 6 volt. Be sure the voltage is correct for your ride. I smoked one because I just assumed it was 12 volt.
    It wasn't.
  6. Doublepumper
    Doublepumper
    from WA-OR, USA
    Yep, they are six volt. Need a different motor or resistor/s to work on twelve volts.
    Tow Truck Tom and 41 GMC K-18 like this.
  7. Ziggster
    Ziggster
    The electrical lead to the motor looks like it had seen better days. Probably should replace it. Also, if cars of that era didn’t use pressurized coolant systems, a straight tube would likely be fine, but if coupling into a coolant system that is pressurized, it might be a good idea to be a bead on it rather than risk have the hose slip off and losing all your coolant.
  8. In_The_Pink
    In_The_Pink
    Soldering a pre-soldered copper coupling onto the brass(?) inlet and outlet would give you double flares:
  9. This probably goes without saying but be sure and check that old core for leaks. They are prone to that and a sizable mess it can make.
  10. miker98038
    miker98038
    Pink’s idea is good. I’ve also had good luck sweating a couple of ferrules for compression fittings on. Far enough apart for the hose clamp to go in the middle. Pretty cheap and easy if it’s stand size tube and you’ve sweated copper pipe before.
  11. topher5150
    topher5150
    -I noticed that wire too. Definitely going to fix.
    - would a compression fitting be ok? My bottom hose ended up to close to the tranny dipstick and I'll need to make a 90.
    - would the inlet be coming from the pump or the intake?
  12. Doublepumper
    Doublepumper
    from WA-OR, USA
  13. 48ford
    48ford
    I took the old motor out,took it up to orillys and matched it up with a 12 volt motor.
    For a heater core I got one that fit a 1989 toe
    We car,fit pretty good,used pipe insulation tubes to wedge everything together
  14. topher5150
    topher5150
    an 80's what???
    41 GMC K-18 and 49ratfink like this.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  16. BJR
    BJR
  17. 49ratfink
    49ratfink
    I read somewhere that you don't want to do any pedal to the metal driving with the heater valve open, that could blow them out.
    don't they make a little tool to add a flare to the end?
    I ran mine on 12 votes, they just spin faster. of course I hardly used it here in sunny California.
  18. warbird1
    warbird1
    That tubing might be a little hard to put a bead on. I simply wrapped a piece of 12 or 14 gauge copper wire around the end of the tube and soldered it. And I'm only running a 7 lb. cap on the radiator to protect the honeycomb heater core.
  19. Kerrynzl
    Kerrynzl
    Easier to get a plumber to flare it with a crox tool
  20. In_The_Pink
    In_The_Pink
    Just be sure to consider serviceability-- if you have to remove the heater itself at some point in the future, adding a 90* fitting on either the inlet or outlet would make that very difficult.
    For a replacement motor, remove the old one and measure the shaft diameter and length, as well as the motor body diameter and distance between the two mounting studs. Armed with that info, search online for 12V (or 6V) blower motors.
    Here's the motor I purchased: https://www.partdeal.com/red-dot-two-speed-12v-single-shaft-motor-73r0082.html
    And some pics of it with my Arvin heater: https://www.jalopyjournal.com/forum...2-rambler-wagon.1291532/page-11#post-15545901
  21. deathrowdave
    deathrowdave
    from NKy
    They produce heater hoses with prebent 90* ells
  22. mgtstumpy
    mgtstumpy
    Not sure what drive-line and radiator you have. I believe core could rupture with too much pressure as these are designed for older low pressure systems.
  23. At the risk of getting off topic, does anyone know a part number for a universal shut-off valve for 5/8" heater hose?
  24. 34Phil
    34Phil
  25. BJR
    BJR
    1975 Dodge pickup trucks had a cable operated heater control valve. Works to regulate the flow and temperature and shut off the coolant to the heater.
