Hot Rods The ALTERED thread
Discussion in 'The Hokey Ass Message Board' started by loudbang, Mar 3, 2016.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think the contemporary thinking was drag strips are flat. You don't turn on a drag strip. There should be little need for shock absorbers. I also think the typical understanding of chassis dynamics was rudimentary, with torque reaction, bump steer, and roll control being of secondary importance to just making as much power as you can in the smallest, lightest vehicle possible. Hence, adequate "shock absorbers" or more correctly, dampers, were of minor concern. When traction improved in later years shocks became more important.
  2. Sky Six
    Sky Six
    from Arizona
  3. 40ragtopdown
    40ragtopdown
  4. bchctybob
    bchctybob
    I believe that is the Woody Duke Olds powered Fiat.
  5. bchctybob
    bchctybob
    I think you’ll find that most of them do have some form of shock absorber in front. They used everything from dinky motorcycle shocks to little lever action shocks from Anglias along with store bought and homemade friction shocks. Often the friction shocks were incorporated into the levers of a torsion bar set-up.
    Back in the ‘60s I raced my ‘33 Ford several Saturdays in B/A before they noticed that I didn’t have front shocks. They made me put some on or they wouldn’t let me run any more.
  6. 40ragtopdown
    40ragtopdown
  7. ratster
    ratster
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I do not think the excessive % of engine setback would qualify that to be an altered roadster.
    More like a Comp Roadster.
    Just Gary, mad mikey, Sky Six and 3 others like this.
  9. 40ragtopdown
    40ragtopdown
  10. Stan Back
    Stan Back
    Agreed. Most likely an early shot that was deemed "Comp" before the 25% set-back rules were addressed by most of the track by using "Altered" or just "Roadster".
  11. 49ratfink
    49ratfink
  12. ratster
    ratster
    glad ur here to tell me what we have, thanks old buddy
  13. 40ragtopdown
    40ragtopdown
  14. 49ratfink
    49ratfink
  15. 49ratfink
    49ratfink
  16. 49ratfink
    49ratfink
  17. 49ratfink
    49ratfink
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  19. As are the Simca 5 which is usually the coupe version of the open Topolino.
  20. 40ragtopdown
    40ragtopdown
  21. Sky Six
    Sky Six
    from Arizona
  22. Sky Six
    Sky Six
    from Arizona
  23. Sky Six
    Sky Six
    from Arizona
  24. Sky Six
    Sky Six
    from Arizona
  25. Sky Six
    Sky Six
    from Arizona
  26. The REAL monsters of drag racing!^^^^^^^^
  27. Sky Six
    Sky Six
    from Arizona
    Little cars, big engines, and throw a brick on the pedal.:)
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Not to mention
    short wheelbase
    high CG
    open air
    mad mikey likes this.
  29. Sky Six
    Sky Six
    from Arizona
