History Barn find T-Bucket
Discussion in 'Traditional Hot Rods' started by Skelgas, May 20, 2025.
  1. Skelgas
    Skelgas
    Anyone recognize this car? Just bought it out of central Kansas. Looks like a 60’s build. Had an early Pontiac in it. IMG_1557.jpeg IMG_1558.jpeg IMG_1552.jpeg
  2. wheeltramp brian
    wheeltramp brian
    Really cool,got a pontiac for it?
    guthriesmith likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    No shackles on the front springs , something's gotta give ...
    vtx1800 likes this.
  4. Squablow
    Squablow
    Very unique chrome front suspension on there, I wonder how well it worked? Should be identifiable by that, I'm sure it's one of a kind. What is the rear suspension?
    Outback likes this.
  5. Tim
    Tim
    from KCMO
    I think when guys use quarter eliptic springs as a links ( as in a four link) as well as a spent they sometimes don’t use a shackle
    Stock Racer and Outback like this.
  6. Jay McDonald
    Jay McDonald
    Bump steer police should be here any time, lol (and they are not wrong)
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    That's not being used as a link , it has some sort of cobbled wishbone configuration .
  8. tubman
    tubman
    Given that it's set up with quarter-elliptics, I wouldn't worry about that so much as the difference in the center of the suspension pivots between the radius rods and the springs themselves (that act as a front suspension component). If the front suspension doesn't tear itself apart first, the caster is going to change radically as the suspension goes through it's normal travel. I see it has what looks like cowl steering as well. I think there's a reason it's sitting in a barn without an engine.
    Hollywood-East likes this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    The axle is being controlled by the bones , radius rod whatever, the spring is being used as a spring , without shackles to allow free movement , it will bind . The caster is not being controlled by the spring ( unless it overpowers the radius rod .
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    wow... and a CRAGAR steering wheel!!!
  11. DDDenny
    I won't join in on the engineering side but it appears to be an era common home interpretation of what "might" work.
    I will say, like many from back in the day it could be one loose bolt away from disaster. Sure hope ALL the bolts have some form of locknut on them when finished.
    Sharpone likes this.
  12. Skelgas
    Skelgas
    No, not sure what’s going back in it.
  13. Skelgas
    Skelgas
    Ford nine inch with a buggie spring
    Okie Pete, Sharpone and Outback like this.
  14. Skelgas
    Skelgas
  15. patsurf
    patsurf
  16. RodStRace
    RodStRace
    Good to see another early T-Bucket. I'll add a comment on the front suspension design. You have heard what to look at and check carefully. I will mention that most Ts only have 3-4 inches of travel, so while things may not be freely moving and have different angles, it's not as crucial as a long travel setup.
    Does it show signs of road use, or more like an unfinished garage dweller? It looks like it was wired and plumbed, so it probably was taken around the block, at least.
    Can you share pics of the steering box and rear suspension too? That front end should be the main identifier, but more info is always good.
    What are your plans? Member for 15 years, only 36 posts, Hope to hear more.
    Okie Pete, mad mikey and Sharpone like this.
  17. Skelgas
    Skelgas
    I concur on all the concerns for the front end. Also agree that it likely didn’t see many miles. It is fully wired and looks to have been complete and drive-able at some point. As far as plans, not sure just yet. I need to determine what transmission will fit in the tunnel and go from there. (It is setup for a manual trans so I am a little concerned an automatic won’t fit under the floor). I have a 392 hemi with a 3 speed manual that might go. Good intuition on my 15 years and very few post. Been busy being a dad. Still love cars. Particularly like the old T-buckets from the 60s. They are cheap and a form of art. (I bought this T-bucket for $2000). I will post more pictures. It has some cool old stuff up underneath.
    Tim, Okie Pete, Sharpone and 2 others like this.
  18. RodStRace
    RodStRace
    Glad to hear it.
    As far as a trans fitting, the floor is most likely plywood, although some were 'glass. Either way, clearance is a saw blade away. I'd hesitate on hacking until everything is checked out and a plan of end product firmly established.
    On desktop, you can just hover over the member's avatar and those stats show. I've been following T bucket threads for a while and got my own a year ago, so keep an eye out for new people. :cool: Don't worry, no cause to press stalking charges!
  19. Skelgas
    Skelgas
  20. Skelgas
    Skelgas
    Operation Hemi.
    Tim and Sharpone like this.
  21. I’d drive it
    Paul B and Sharpone like this.
  22. snoc653
    snoc653
    from Iowa
  23. Fordors
    Fordors
    Uh,no, too small. That’s just a Cal Custom air cleaner
  24. Sharpone
    Sharpone
    Nice, very cool 70s vibe
    Dan
  25. Okie Pete
    Okie Pete
    Looking good
  26. That's turning out pretty good
  27. Tim
    Tim
    from KCMO
    Now that’s cool!
