Projects 3rd car, the "Local" Build
Discussion in 'Traditional Hot Rods' started by jim1932, May 6, 2025.
  1. jim1932
    jim1932
    1. Ford A and B speed
    At a minimum I don't need antifreeze running into my Bow target....LOL
    enloe and winduptoy like this.
  2. jim1932
    jim1932
    Oil pan off. Someone liked the blue gunk!
    Toms Dogs, Okie Pete, Outback and 6 others like this.
  3. jim1932
    jim1932
    next is to see if I can drop the flywheel on my foot. I know, rotate the block till the flywheel is on top, then take it off.
    Okie Pete, Outback and winduptoy like this.
  4. jim1932
    jim1932
    OK on to the fun job of getting the oil pump off. Who ever rebuilt this was damn good at wiring bolt heads. IMG_8359.JPEG IMG_8360.JPEG
  5. jim1932
    jim1932
    Researched on the HAMB the difficulties getting pump off. I used a towel for protection and a pipe wrench a couple twists and it worked right out.. into the diesel bucket it goes.
    V8-m, enloe, Toms Dogs and 3 others like this.
  6. jim1932
    jim1932
    OH.... if anyone is reading this on how to tear town a flathead. There is an annoying pan bolt on the opposite side by the starter.
    winduptoy likes this.
  7. winduptoy
    winduptoy
    good progress..all in all the engine appears to be pretty fair...I've seen a lot worse and I suspect you have too...thanks to non detergent, reclaim oil and the such... apparently you didn't drop a flywheel on your foot
  8. jim1932
    jim1932
    Much lighter than a Model B flywheel.
    lothiandon1940, winduptoy and Outback like this.
  9. jim1932
    jim1932
    OK...... advice needed. I am kind of at a point of no retern between cleaning it up and running it as is, or doing a full rebuild. How do you determine if it is sound enough to run? Story is it was pulled out of a truck. makes sense, not tons of wear, but typical 80 years of old oil.
    Okie Pete likes this.
  10. Grumpy ole A
    Grumpy ole A
    To me it depends on the main and rod bearing wear and the cylinder wall wear.
  11. plastic-gage and micrometers are your friend.
  12. Outback
    Outback
    from NE Vic
    Exactly
  13. jim1932
    jim1932
    OK time to learn a new skill Plastigage and inside bore guages ordered.
  14. winduptoy
    winduptoy
    I'm a hack...and this is a local build for you.
    just 'overhauled' engines that have gotten me a lot more smiles....$/fun ratio and going to cruise, pose, not race....assembled so it doesn't leak oil...though that can be a dust suppressant and rust inhibitor
    not too much cylinder bore scoring or wear indicated by ridges...'reasonable' journal to main clearance
    no cracks in the engine deck
    what kind of ridge do you have in the cylinders?
    what do the crank journals, rods and mains visually appear like? how dirty/scored are the bearings
    same goes for the lifters and cams...a good looking at, has someone put adjustable lifters in it, a sign it was internally worked on at some point
    valves appear good....
    mic the rod and main journals on the crank...how close are they to the dimension for stock diameter, .010" under, .020" etc... then....
    I have used the tin foil method to check crank/rod to journal clearance
    this works best if you have all rods out for checking the mains...and leave the main caps off all but the one you are checking
    then check rods one at a time...keep track of what came out of where
    most foil is .0015" thick...measure it though...I cut a square patch out, place it on the journal and re-torque to spec.
    try to turn the engine over, if it turns freely you have more than .0015" clearance
    add another square, making sure you don't wrinkle or fold any edges over...re torque...if the crank turns freely, the clearance is larger than .003" if it locks up, your clearance is between .0015" and .003" wonderful
    get the idea.....
    with your bore gages, taper or out of round is going to be cause for ponder....though I use inside micrometer that I got on the cheap in a antique shop...I am an admitted hack that has gotten away with a lot of shade tree stuff over the years depending on how far from home I was going to travel with the set up....I won't go into the 220 Silver Diamond IH engine 'overhaul' in my Hough loader that never leaves the property
    hope this helps and good luck and this is worth what it cost you
    Larry
    G Baese, dmar836, Toms Dogs and 3 others like this.
  15. sheza65
    sheza65
    from Utah
    It looks rough!
  16. jim1932
    jim1932
    Yeah, forgot to post that. Gears are all pitted.
    Okie Pete and winduptoy like this.
  17. jim1932
    jim1932
    OK So no matter what, I am tearing it down and marking what came from each cylinder. So time to go after the valvetrain. the pistons say STD so I am wondering if this cylinder broke a ring. Walls look good though.
  18. winduptoy
    winduptoy
    something got down the intake....
    that bore looks good....real good....I have a feeling you are going to get lucky
    Toms Dogs likes this.
  19. phat rat
    phat rat
    By the looks of the internels I'd have it hot tanked. You don't know what's in the oil and water passages
  20. TennM5
    TennM5
    @ Winduptoy: what a GREAT summary of a shade tree overhaul. Thank you, very much.
  21. jim1932
    jim1932
    did you not see the brown sludge from tking off the water pumps? I know the passages are full of shit. I can dip it then put everything back, but at that point.... slippery slope. Replace the bearings, leads to machine work and the next thing you know you bought a blower and ardun heads...... LOL
    dmar836, Okie Pete, Toms Dogs and 3 others like this.
  22. winduptoy
    winduptoy
    I hear you big time....I might just be inclined to deep clean all internals with diesel fuel, verify everything doesn't look like it is going to fly apart, three stone hone and cast iron ring it... using the standard pistons in it....you do have a groove cleaner....every local builder needs one
    then back flush the cooling system after you get everything together in the car, I'll take a picture of my local build, backflush set up.... use Iron Tite cooling system cleaner after it is ready to run....drive it....drain and re-back flush
    thinking out loud.....it is $/fun ratio
    G Baese, Deutscher and Thor1 like this.
  23. winduptoy
    winduptoy
  24. phat rat
    phat rat
    Yes I saw the picture but so many were saying to just run it. I agree about the slippery slope but then at least you'd be able to trust what you have. Of course if you only plan on putting around town, just cheap out, you'll never be far from home and tools
    G Baese and winduptoy like this.
  25. Bearing Burner
    Bearing Burner
    from W. MA
    Your very LUCKY that the were no cracks .
  26. jim1932
    jim1932
    Interesting, this has a Ford rebuild tag, but the bores are still 3.06. I have not had the chance to check the mains.
    FYI this build will be on hold for a while. My Neighbor who was friends with my Dad, and taught me a ton on restoring things the right way, passed away suddenly. I need to help them get some of his vehicles going for his celebration of life. if anyone has experience with 1920's Dodge (firetruck) PM me.
  27. winduptoy
    winduptoy
    The mains will be good to use again... that is my prognostic guess
    Sorry for the news about your neighbor...it is a tough way to get help to get vehicles running.
    I don't know if the Dodge fire truck had dual ignition by then...it will be just like a car...compression, fuel, spark all at the right time...
    Best of luck
    Thor1 likes this.
  28. Cliff Ramsdell
    Cliff Ramsdell
    The Dodge will be a 12 volt system, negative ground. The fuel system used a vacuum for a fuel pump. Pulls manifold vacuum into a container and that draws fuel from the rear mounted tank and then gravity feed to the carb.
    The car transmission is a 3 speed, H pattern and its 1st gear is to the left and up, 2nd gear is down and to the right and 3rd is straight up from 2nd. Reverse is straight down from 1st, Its opposite from a ford 3 speed and makes it quite roomy to drive without the shifter down by your legs.
    Generator and starter and combination unit, it starts and charges, well that's the way it should work. Ours never charged, have a really good battery.
    I don't know how much I forgot over the years, the Dodge dealership I was the shop foreman at, late 80's early 90's had a 1916 Dodge touring car we would drive in parades.
    Hope this helps,
    Cliff Ramsdell
  29. Cliff Ramsdell
    Cliff Ramsdell
    G Baese, Toms Dogs, Deutscher and 3 others like this.
  30. BJR
    BJR
    That's not a fuel pump, it's a vacuum tank.
