Hot Rods frame is 38..title is 38 chevy....BUT????
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Apr 2, 2025.
  1. ALLDONE
    ALLDONE
  2. ALLDONE
    ALLDONE
    what is it??? can you put a 37 grille on a 38??? or is the whole body a 37??
  3. ALLDONE
    ALLDONE
    the hood opens like this, I read that there is only one place that makes these... up in oregon???
  4. alchemy
    alchemy
    Switch out grille and hood. Show a rear view of rear fenders.
  5. squirrel
    I don't know how you can tell the different between a 37 and 38 frame, Chevy never stamped numbers on them, and they look the same to me.
    The 37 and 38 body are the same, the front sheet metal is different.
  6. 34Phil
    34Phil
    This is the only group that would know the difference, so don't call attention to title.
    19Eddy30 likes this.
  7. Joe H
    Joe H
    Swapping front sheet metal is all thats required, the trucks are the same way for those two years.
    Okie Pete, chryslerfan55 and ALLDONE like this.
  8. Fogger
    Fogger
    The most beautiful convertible Chevy ever made, just my opinion.
  9. alchemy
    alchemy
    The rear fenders have a slight difference in width. But I’m not sure which is which.
    chryslerfan55 and squirrel like this.
  10. ALLDONE
    ALLDONE
    I had a 37 years ago,... numbers didn't match the motor because it was long gone... the guy at dmv in vegas found them on the dr side rear frame past the rear tire... they did reg. off that
  11. ALLDONE
    ALLDONE
    wasn't superior glass the only ones that ever made these bodys???
  12. 1971BB427
    1971BB427
    from Oregon
    I believe Old Chicago in Molalla, Oregon built bodies for '37-'38 Chevys, but not sure they ever built a convertible? The shop burned down years ago, and was never reopened as a fiberglass Chevy parts provider again.
  13. poco
    poco
    from oklahoma
    I had a 38 conv many years ago, was in a salvage yard when i bought it. Did a valve lob and it ran fine for several years.
  14. Black Panther
    Black Panther
    from SoCal
    Front sheetmetal doghouse assembly, grille, headlights and hood are different. Front fenders are the same. Firewall back it's the same. 38s have slightly wider rear fenders as others have mentioned.
    Okie Pete and ALLDONE like this.
  15. 38 Rear fenders are 1" wider on each side, making a total of 2" wider rear track width.
    To the original poster, the hood and grill shell / radiator doghouse can be swapped between 37 and 38.
    There are other differences but they are mainly bolt on things like bumpers, speedometer, and as mentioned rear fender width.
  16. Well, GM made them originally in steel, but they all had rumble seats. Superior glass convertibles had trunks like a coupe, other than the obvious fact they are fiberglass.
  17. Joe H
    Joe H
    Frames were not stamped with any numbers associated with the VIN. The only numbers were body serial number, on the cowl. The VIN at that time was the engine serial number, and if the engine was swapped out, the VIN went with it.
    ALLDONE, 50chevytx and Dan Hay like this.
  18. proartguy
    proartguy
    from Sparks, NV
    In ‘37 and ‘38 Chevys used similar frames, but I believe there is is a difference in the angle of the rear section. The rear axle is wider on a ‘38.
  19. Mr48chev
    I've never seen an early Chevy with a serial number or partial stamped on the frame. That includes all of the 47/54 Chevy pickup frames I have had.
    These pages snagged from the PFDs for 37 and 38 Chevy from the GM Heritage center archives show both 37 and 38 serial numbers and locations. The other two pages show the measurements for 37 and 38.
    37 PFD https://www.gm.com/content/dam/comp...information-kits/chevrolet/1937-Chevrolet.pdf
    38 PFD https://www.gm.com/content/dam/comp...information-kits/chevrolet/1938-Chevrolet.pdf Screenshot (753).png Screenshot (754).png Screenshot (756).png Screenshot (757).png
  20. 24riverview
    24riverview
    What proartguy said. And if you're wondering, 39 is similar to 38 except the upper rear shackle mount goes through the side of frame.
    1937
    chevy_6-1.jpg 1938
    Okie Pete and chryslerfan55 like this.
  21. ALLDONE
    ALLDONE
    HERE'S A FACT ABOUT THIS CAR.... IT'S AUTO TRANS AND POWER STEERING.... i'M GONNA DRIVE THE WHEELS OFF IT... IMG_4815.jpg
    Okie Pete, Dan Hay and vtx1800 like this.
  22. wasn't there a State that titled cars by the year the car was sold? or was that way before the thirties? I remember hearing something to that effect.
  23. ALLDONE
    ALLDONE
    Not much to do to this one but drive it
    Okie Pete and hotrodjack33 like this.
  24. ALLDONE
    ALLDONE
    inside is do able for a daily type driver,seats are comfy..and the red is not too bad..huge trunk for parts runner
  25. ALLDONE
    ALLDONE
    for once, the stance is right,as is the tires and wheels...
    but... the one time in band camp exhaust tips gotta go...
    maybe lake pipes???? lol
    Okie Pete, hotrodjack33 and vtx1800 like this.
  26. douglasb
    douglasb
    Man Steve your going to need to get another lift soon. Nice one
    ALLDONE likes this.
  27. 38's have a wider rear 1/2 of the rear fenders,...your ragtop looks Austrailian to me..
    ALLDONE likes this.
  28. primed34
    primed34
    Car number was stamped on a plate attached to the passenger side floor at least thru '39.
    ALLDONE likes this.
  29. Mr48chev
    Depending on when it was built as a hot rod/custom it may be as simple as the builder thinking that the 37 nose was better looking than a 38 nose. Or the car got wrecked years ago even well before it was made into what it is today and there was a real nice 37 nose sitting the wrecking yard and no car with a good 38 nose, don't overthink it. Right now, I 'd drive the daylights out of that car with a great big grin doing it.
    ALLDONE likes this.
  30. 1971BB427
    1971BB427
    from Oregon
    Vin tags were on the body on the passenger side cowl. At least that's where mine is on my '39 and pretty sure '37-'38 are also.
    vtx1800, deathrowdave and ALLDONE like this.
