Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Moondog13
    Moondog13
    I’ve been trying to figure out what this is out of, if anyone recognizes it. It came installed in a ‘48 Ford I just got and it looks pretty viable so I’m trying to save it if I can. IMG_2047.jpeg
    Sharpone likes this.
  2. ^^^^^looks like a gm product similar to the one I used from a 66 Nova
    Sharpone and Moondog13 like this.
  3. For you guys who use CLR to de-rust parts, do you reuse the CLR after you take the parts out?
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Color code of wires isn’t GM in my eye’s.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Maybe :) IMG_3845.jpeg
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    DSCN0341.JPG Winter Changing Of Fluids In The Bombs..
  7. Looks similar to the layout on my Painless, if nothing else you can see what fuse is what. My original painless from the 90's had thick pink wires like that, but they were numbered to correspond with their chart (before they labeled wires).
  8. Moondog13
    Moondog13
    Sharpone, pila38, swade41 and 2 others like this.
  9. bymanr
    bymanr
    thumbnail_IMG_3904.jpg Need some hood aides for the Avatar
    thumbnail_IMG_3902.jpg Cardboard aided design...
    thumbnail_IMG_3993.jpg I had to trim some protrusions around the carb. base to clear hood panel..
    Finally able to use Dzus tabs that Marty Strode made for me ~5yrs ago..
    thumbnail_IMG_3994.jpg thumbnail_IMG_3995.jpg First time for me installing Dzus fasteners...they work awesome..
    Getting closer...
    Red on the latches will go away...planning on louvers soon...
  10. choptop4
    choptop4
    20250214_164121.jpg finally finished my woodgrain.
  11. bymanr
    bymanr
    My brother Erik (@embyman68) on here lining up for a go at punching some louvers with his newly created Louver Press.
    Concentrating.....punching like a hot knife through butter. thumbnail_IMG_4012.jpg
    Backside.. thumbnail_IMG_4014.jpg Frontside..
    Nutserts and lineup pins installed on hood top. thumbnail_IMG_4027.jpg thumbnail_IMG_4028.jpg Very happy with the results..for a couple of amateur fabricators.. at some point I would like to make a blister for
    the alternator and also some type of scoop/blister for the air cleaner.... we'll see if that happens. Rich
  12. Zax
    Zax
    1. 1952-59 Ford Social Group
    Got the 39 trans in my Roadster
  13. lumpy 63
    lumpy 63
    IMG_20250215_161752.jpg IMG_20250215_161747.jpg IMG_20250215_161747.jpg IMG_20250215_161717.jpg Pulled the front sheet metal off the Tempest. Arizona cars are super rust free but man there is fine dust EVERYWHERE...I'm not a huge red fan but it is a pretty nice shade.
  14. saltflats
    saltflats
    from Missouri
    I was in the mix of restoring a 62 Impala SS that is a California car. I never had bolts come out and look like new before. Living in central Missouri we don't see that very often.
  15. Lumpy graciously gave us a pair of Ram Horn manifolds for Papaw. I changed the exhaust pipe flange studs and backed out the old ones by hand with no heat, trouble or drama. I’ve never in 34 years of working on cars and trucks ever had that happen. My guess is they were California parts and came from a dry area.
  16. lumpy 63
    lumpy 63
    I hope to see some driving videos as soon as spring arrives in your area Andy:cool:
  17. pila38
    pila38
    I wish man. I don’t know what it’s like to remove a bolt without a struggle.
    porkshop, mad mikey, Sharpone and 7 others like this.
  18. saltflats
    saltflats
    from Missouri
    It's the same way for my stuff. I only get lucky every now and then on customer cars.
  19. lumpy 63
    lumpy 63
    I still don't try and loosen lower fender bolts... it usually breaks the tangs off the captured nuts. I tighten them until they snap off.
  20. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    Lumpy, that sheet metal is amazing. In the northeast, dust makes rust!
    Lumpy, we are down to the front brakes, master cylinder, and shifter. We are using Bendix backing plates from a car on the front and someone had drilled a bunch of extra holes on the lower side and reamed them out when they didn’t line up. Little Truckdoctor welded up the holes and ground down the welds. Then we accurately located the holes and re-drilled them. The last thing we got done was to paint the backing plates before the weather turned cold and snowing. I’m going down to Lloyd’s in March to hang out and work on his wagon. I’ll pick up the shifter then. I’m hoping to have it ready for a car show and open house at my Alma Matter, Ranken Technical College, on April 5. Little Truckdoctor is seriously considering going there for Diesel Technology.
  22. lumpy 63
    lumpy 63
  23. atch
    atch
    Pix after paint, Andy. We need pix after paint...
    porkshop, pila38, mad mikey and 7 others like this.
  24. lumpy 63
    lumpy 63
    20250216_104043.jpg Finished the rear suspension 20250216_110450.jpg My pal Dennis stopped by with his coupster , he just got it back on the road after some upgrades
  25. Ok, I’ll shoot some after the paint job, but just to warn you, I got lazy and didn’t bead blast them. I should have taken the time, but was running late the night we painted them.
    Today, we removed the Huck brake drums from the hubs. The Bendix style drums mount differently and I’m going to take the hubs to work and steam clean them. The wheel studs were swedged to the hubs. I’ve read various threads on here, but we’re not completely clear on what people were talking about. Not wanting to buy a swedge cutter or ruin my hubs, we drilled the ass out of each stud, then drove them out forward. I should have taken them out to the shop and used the drill press, but damn, it’s cold out there. We used a hand drill and my arms are tired. IMG_8966.jpeg IMG_8963.jpeg
  26. Messing with an R10 OD
    Had this solenoid that came with some parts
    Works. Came with a gm set up so should be 12v still cleaning it up to look for numbers
    The longer one is what was with the Merc trans
    these reverse lockout switches ohm out. But seem to be too short to make contact with the internal shaft IMG_4937.jpeg
    And I guess I need to either carefully unfold the terminal crimp or clean and solder a new wire on the governor.
  27. Maverick4130
    Maverick4130
    image.jpg image.jpg Workin on the interior how dose the front and rear arm rests supposed to fit?
    1953 Ford Customline two door
  28. patsurf
    patsurf
    prob good you aren't teaching them english ...anthony!
    pila38 likes this.
  29. pila38
    pila38
    Clutch done. Bellhousing done. Engine in.
