Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. Hemi Joel
    Hemi Joel
    from Minnesota
    Checker trivia: From 1933-1937, Checker was owned by the Cord Corporation, manufacturers of the Auburn, Cord, and Duesenberg cars.
    bchctybob, porkshop, Sharpone and 5 others like this.
  2. squirrel
    I think Mr Cord owned the Checker Corp for a few years, but it wasn't really related to the Cord Corporation? The owners of both companies knew each other....
    Anyways, back to Corvettes, I put the old Heathkit scope that Russ brought me, on the Corvette. Looks like the distributor wobbles a little, but it's sparking OK.
    Outback, porkshop, bchctybob and 11 others like this.
  3. Jeff Osstyn
    Jeff Osstyn
    Jim,
    Does it tell you if the sparks are happening an equal distance apart of 45 degrees? Tells you if the lobes are worn unevenly. Which would then have an effect on spark timing in each cylinder to be different. Just a thought.
    porkshop, bchctybob, Sharpone and 2 others like this.
  4. squirrel
    The video shows the superimposed image of all the cylinders, and you can see it wobbling back and forth a little. I expect there is a little bit of timing difference.
    I still have to play with it more to get the "parade" pattern working right...
    porkshop, bchctybob, Sharpone and 4 others like this.
  5. chicken
    chicken
    from Kansas
    Does it have a raster pattern setting as well? ( wave forms stacked)
    porkshop, bchctybob and 41 GMC K-18 like this.
  6. squirrel
    no, it's not that fancy. The Sun scope I had years ago did, but it also had a big TV picture tube, not a little 5" round CRT.
    Outback, porkshop, bchctybob and 3 others like this.
  7. chicken
    chicken
    from Kansas
    Yeah, my Sun did too....and I miss it as well. Didn't have room for it but damn it was so handy.
  8. squirrel
    Mine was huge, but it also quit working, and I'm not very good at fixing 1970s TVs, unfortunately.
  9. Phil P
    Phil P
    It's not like the good old days:D oj3pf14lb3551.jpg
    Phil
    Outback, porkshop, bchctybob and 5 others like this.
  10. TrailerTrashToo
    TrailerTrashToo
    Like it's former owner, it never was quite stable;).
    Russ
  11. noboD
    noboD
    I can't believe it. Something built in the 20th century that Squirrel can't fix.
    Outback, porkshop, bchctybob and 6 others like this.
  12. chicken
    chicken
    from Kansas
    Mine was like this one.
    Outback, warbird1, porkshop and 6 others like this.
  13. squirrel
    This was mine.
    Outback, porkshop, Tim and 10 others like this.
  14. patman
    patman
    You can get electronic oscilloscopes pretty cheap these days, just plug on to a USB port on a computer notebook. Wonder how good something like this is:
    https://www.ebay.com/itm/405223513142
    porkshop and Sharpone like this.
  15. squirrel
    Yeah, but somehow that takes all the fun out of it :)
    porkshop, Baumi, chicken and 3 others like this.
  16. saltflats
    saltflats
    from Missouri
    I saved my scope from my shop in town when I closed it. It is a more modern brand that will do up to 8 coil on plug ignition systems, not that big of a piece of equipment. It's in storage for now.
    Outback, Sharpone, bchctybob and 3 others like this.
  17. deathrowdave
    deathrowdave
    from NKy
    I have been offered a couple old sun scopes , I have no remaining space .
  18. Pontmerc
    Pontmerc
    from Finland
    Mine.its handy because its so compact size.even has all hei distributor test equipment. 17331277120973417689732009307439.jpg
  19. squirrel
    Let's see...it's summer, so it must be time for another adventure.
    Heading up north tomorrow. Las Vegas for overnight visit with friends, then up to Tacoma for the LeMons Rally--Cascades of Failure.
    I think the car is mostly working ok, although that is subject to change without notice.
    I made a few repairs recently. Nothing major. A new rear wheel bearing on the driver side last spring, and I replaced the cruise control module, as it had been getting flaky, after being in a dozen different cars over the past 15 years. And I added an Android Auto screen, which is probably going to just cause problems, since it's kind of too dim to see when the sun is out and the top is down.
  20. patsurf
    patsurf
    do you have the points set ,condenser ,and extra axle brg in the glovebox?
    porkshop, enloe, Outback and 2 others like this.
  21. squirrel
    I have them in the plastic tub in the trunk. Just inventoried...two sets of points, two condensers, one wheel bearing. Fan belt, a few small misc things, tool box, jack and stands. And lots of water to drink, and some for the car if it gets thirsty. Plus an extra quart of oil. I just did an oil change/lube, also.
  22. patsurf
    patsurf
    :):):):cool::cool: heck-you will be the chevy mechanic for the whole group!!
    porkshop, enloe, Outback and 3 others like this.
  23. Sharpone
    Sharpone
    Good luck
    Dan
    porkshop, squirrel and 41 GMC K-18 like this.
  24. saltflats
    saltflats
    from Missouri
  25. Good luck, Jim. Color me envious.
    May I ask what cruise control you are using?
    Ben
    porkshop, enloe and Outback like this.
  26. 41 GMC K-18
    41 GMC K-18
    Hey @squirrel
    Here is my information, let me know when you are going to be at the Lemay museum, I will come down to say howdy. I assume you are comfortable wearing either a large or an extra large T-Shirt, just let me know what size and I will provide you with a nice Rooster shirt, which is one of my designs if you would like one.
    Also one of the best drive ins for great food is the well known Pick Quick hamburger stand there in Fife, if you have time to enjoy it. You wont be disappointed!
    https://www.mapquest.com/us/washington/pick-quick-drive-in-303169177
    Thanks from Dennis.
    ball graphics business card 2.jpg IMG_0924 (3).JPG Pick-Quick-lawn-e1548322514786.jpg PICK QUICK.JPG
  27. squirrel
    that looks like fun! I'm planning to stay near the museum Thursday night. XL.
    I have no idea when I'll get there. Also planning to meet up sometime with a couple other guys in the area who are going on the rally. It all depends on how the car does on the trip up, etc. And traffic :)
    Rostra/Dakota Digital Globalcruise is in there now. .
  28. Bag is packed. Ready for another Squirrel adventure.
  29. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Thanks for posting all your adventures Jim! It helps motivate the rest of us (or at least myself) to want to do similar. :cool:
  30. 41 GMC K-18
    41 GMC K-18
    Well you have my number, so you can text me when you are in the area.
    Also as an added extra, and only if you have time, its not that far from Tacoma to Kent Washington, and on the Friday afternoons till late in the evening, there is this great gathering that goes on at a great venue
    at Binford's wrecking yard.
    I will include the two links here that will let you see just how much fun this is.
    Enjoy from Dennis.
