  1. Country Joe
    Country Joe
    No photoshop expert here but, what do y'all think of the 51/41 Willy's F1 ???
    I parked my truck visiting a friend and I was looking at my truck from across the yard. A big shrub was blocking my view of the back half of the truck, and I started to imagine a coupe with the truck front. Wondering if it looked good or not. I think it would look pretty good. Don't worry, I haven't the skill, time, space or money to attempt this combo... just a daydream.
    James D, Ned Ludd, Outback and 4 others like this.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Pretty Cool :cool::cool::cool::cool::cool::cool::cool::cool::cool::cool::cool:
    Country Joe likes this.
    whtbaron, jimmy six and Unclebrad like this.
  4. jnaki
    jnaki
    Hello,
    I had previously drawn an F-1 of Bob Joehnck Automotive of Santa Barhara as a push vehicle for his 36 Ford Coupe.
    I was in the process of giving it a chop. The coupe came out terrible, so it got trashed until later.
    I had previously drawn a copy of what our own 1940 Willys Coupe would have looked if we had painted it yellow and finished it with the added accessories.
    Jnaki
    So, in combining both as has been asked, this is what came out as a certainly odd look. But acceptable given the parameters and scale.
    themoose likes this.
  5. Stan Back
    Stan Back
    Please, I just finished lunch.
    51504bat and southerncad like this.
  6. Shaun1162
    Shaun1162
    Not sure if this possible, but could the people be removed from the background of this photo?
    I took a couple others, but the flag wasn’t showing as well! Thanks for the help
    Bandit Billy likes this.
    Goodmanag, rod1, whtbaron and 8 others like this.
  8. Shaun1162
    Shaun1162
    You’ve done it again Moose! Great work!
    themoose and quakerchevelle like this.
  9. quakerchevelle likes this.
  10. ALLDONE
    ALLDONE
    well, I'm stumped again.... try'n to build a dirt track racer out of this 27... I have a truck bed... but they are way too long... the turtlebacks don't fit... matbe need to fab some thing up... or???? any photo shop ideas???? thanks...2ff
  11. Squablow
    Squablow
    I have a 23-25 turtle deck on what was a '26 T RPU cab and I think it works pretty well, they're cheap too. I did make mine wider which I think helps, it also ended up being an inch longer and taller to accommodate my gas tank but you wouldn't have to do that. Would work with a roll bar.
  12. justabeater37
    justabeater37
  13. ALLDONE
    ALLDONE
    went ahead and bob'd the bed to get done...
    also added a couple bob'd "GREEN" mud fenders for off roading in utah..
    IMG_3323[8992].jpg IMG_3324[8993].jpg IMG_3330[8998].jpg IMG_3331[8997].jpg IMG_3332[8996].jpg IMG_3333[8995].jpg
    justabeater37 and Unclebrad like this.
  14. Stan Back
    Stan Back
    The bed length is just perfect in your truck. After all, it's a 1/4-ton model, not a 1/2-ton.
  15. ALLDONE
    ALLDONE
  16. justabeater37
    justabeater37
    Thanks. The pic is in front of the old Berg Buggy factory building in Farmington, Iowa.
    whtbaron and 2FORCEFULL like this.
  17. fleet-master
    fleet-master
    Hi folks, I have a request ....would one of you awesome photoshop experts be willing to remove both the visor and the front bumper from this 57 ? many thanks in advance
  19. quakerchevelle
    quakerchevelle
    That visor is cool!
  20. fleet-master
    fleet-master
  21. Busted Knuckles
    Busted Knuckles
    If someone could put these skirts on this car, delete the side trim, add star wires upfront with skinny whitewalls, make the skirts a metallic silver flake with a royal purple fog and do the same treatment upfront sort of like the El Capitola. I have a set of aftermarket trim that was to make a 55 Mainline look like a Crestline and the angles are similar to the Cruiser skirts shape. Also please adjust the stance in the proper manner!
  22. Unclebrad
    Unclebrad
    Hope I understood it right...
  23. Busted Knuckles
    Busted Knuckles
    Feom the belt line up should be white
  24. Rot 'n Kustom
    Rot 'n Kustom
    Here is what I have so far. Lowered, shaved, Star Wires on skinny white walls, and cruiser skirt.
    But I'm not sure how to make the rest work. You want 4 colors on this car? White top, blue body, silver skirts, and purple, too?
    Busted Knuckles likes this.
  25. Busted Knuckles
    Busted Knuckles
    Let's drop the flake and purple and add the front cove like the Capitola
  26. Unclebrad
    Unclebrad
  27. Unclebrad
    Unclebrad
    Not sure what you mean by white cove.
    In the picture you sent from your phone, you marked an area around the front wheel well. Do you want a color change there?
  28. Rot 'n Kustom
    Rot 'n Kustom
  29. Busted Knuckles
    Busted Knuckles
    Yes but with the shape much more like the cruiser skirt.
  30. Busted Knuckles
    Busted Knuckles
    More like this. Thank you
