Technical 32 roadster outside door handles location
Discussion in 'Traditional Hot Rods' started by elroots33, May 19, 2024.
  1. Hello,
    Can anyone of you can give me some dimensions to assemble the outside door handles on my 32 roadster ?
    Some pics of the inside mountings will be welcome ! I suppose there are some plates and rods to connect the handles !
    Thanks !
  2. alchemy
    alchemy
    I’d drill through the latch so the handle is in the exact spot needed.
    chevyfordman and Fogger like this.
  3. RodStRace
    RodStRace
  4. BJR
    BJR
    Why do you need outside door handles?
    oj and RICH B like this.
  5. Outside handles are traditional. Shaved handles can be traditional also.
    chevyfordman likes this.
  6. Because I want them !
    26 T Ford RPU, Fordors and BJR like this.
  7. spanners
    spanners
    A car without outside door handles doesn't look finished.
    26 T Ford RPU and Fogger like this.
  8. DDDenny
    I take it then that you're not a fan of hiboys!
  9. Fordors
    Fordors
    There was a dress code at my high school, never knew there was one for highboys, WOW!
    pprather likes this.
  10. DDDenny
    Point was that if missing outside door handles are a faux pas then not having fenders and running boards would be completely unacceptable.
  11. Fordors
    Fordors
    And I completely overlooked your quote of @spanners post. My apologies.
  12. spanners
    spanners
    Highboys don't worry me, and I'll admit to not being a huge fan of them mainly because in Australia we have shithouse roads so fenderless is not a good idea, it's just to me looking down the side of a car's lines and not seeing a handle makes it look like someone forgot something.
  13. Fogger
    Fogger
    It's certainly a personal decision whether your car has exterior door handles or not. It depends on the style and the era depicted during the build. My original '32 Roadster was a restored car when I got it in '06 but all I used was the sheetmetal and frame. I wasn't going to paint it or fill the holes left by the door handles, cowl lights, top rests or grill shell topper. Just my personal choice and it won't be changed.
  14. Sorry guys, my question is not "with or without" but where exactly, I talk about dimensions, must I put them, according to the original Ford location ?!
    Actually, if someone of you got handles on his roadster, can he measure for me the dimensions of their location !
    Thanks !
    Carter and 26 T Ford RPU like this.
  15. I started the other thread, but haven’t installed mine.
    Do you have the latch mechanisms? Can you bolt them in the doors?
    Do like was suggested and take a transfer punch, insert in the square hole from the inside of the latch mechanism and mark the inside of the door skin. This will be the location of the handle shaft’s hole.
    Drill a small hole through from the inside where you made the transfer punch mark.
    Enlarge from the outside, insert the handle assembly and plumb verticals the two mounting screw holes on the bezel.
    Transfer punch and drill the two small holes.
    Tack weld a threaded plate inside the skin and screw on the handle.
  16. Andy
    Andy
    Original body or repo?
  17. xix32
    xix32
    Here is a photo of a sketch showing the location, setting on a roadster door.
    If the drawing isn't clear, it's 1.9" down from the bottom edge of the raised molding,
    and 3" back from the door edge. These dimensions are to the 1/2" diameter hole center.
  18. oj
    oj
    Well, it is an interesting question: door handle or no?
    Considering that a 'Roadster' by definition has no side windows do most roadsters' lack an outside door handle?, they would be unnecessary. I have 3 roadsters (2 Nash Healeys and a Model T) in the shop right now that did not come with outside door handles, any other examples?
  19. chevyfordman
    chevyfordman
  20. Grumpy ole A
    Grumpy ole A
    The 1928 roadsters did not come with them from the factory.
  21. swifty
    swifty
    Henry was a miserable old coot who put off providing features/improvements as long as he could.
  22. Beanscoot
    Beanscoot
    But people are pretty keen on his old cars anyway!
  23. The OP didn't ask what people thought about or what Roadsters came with external door handles so why derail his Thread, create your own and ask away. I hope he gets the handles fitted as they were
    original equipment on 32 Ford Roadsters. Mine had them. JW
    hotrodA likes this.
  24. oj
    oj
    Good point, I saw that the proper measurements had been provided and thought he was good to go.
    My apologies.
    26 T Ford RPU likes this.
  25. Thanks a lot xix32, that's exactly what I need ! Your dimensions are perfect !
    About the other suggestions, thanks too, but I haven't any square hole in my mechanism, just little plates on which we can fix rods from inside or outside handles !
    My body is steel made, from Sweden, I suppose mechanisms are a local making !
