Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. SDS
    SDS
    The "bead" I'm talking about is around the perimeter of the inside of the steel door's surface where the upholstered door panel will sit. The upholstered door panel can sit inside that bead, or on top of it.
    Now that you've brought up wind-lacing, does a 32 Ford roadster even have wind-lacing? If so, where does it go?
  2. nrgwizard
    nrgwizard
    from Minn. uSA
    OK, that clarifies what you're asking. It's been awhile since I've looked closely at roadster doors. I think the upholstery panel edge just gets real close to the inner door panel edge, can't remember the term(door-frame, idk), but it exists 'twixt the door skin & inside door panel. Windlacing use? I'd have to go pic-searching, I can't say for sure. Guess it could/did go either way, with or without, at least for hotrodders. If you do use it, windlacing would go around the front, bottom, & back edges of the panel. Nothing to seal on the doortop edge. A wag would be that it'd be used by the factory, if only as a finishing touch. ??? Now I'm curious myself. :) .
    FWIW.
    Marcus...
  3. chiro
    chiro
    I need some help from the upholstery gurus. I would like to do the kick panels, doors, package tray, etc. in my '30 A coupe. I don't have a sewing machine or the skill so I've been looking at the pre-pleated materials available out there. Anybody have advice as to which ones to buy for this project. Problem is I have a great set of early Mustang Pony buckets in it in the Ivy Gold color which has not been easy to find in the pre-pleated material. Anybody got some pointers?
    Thanks,
    Andy
  4. Sporty45
    Sporty45
    Can you find the material in the color you want? Maybe someone could sew the pleats for you and then you could cut it to fit your needs? Hopefully there is somebody in your area that could help you out.
    drdave likes this.
  5. Did this in my basement. The white pleated material came pre sewn with foam backing. It is made for a boat so the pleats have a pebbled texture to them.
    There are plenty of videos on YouTube for making no sew panels. This is the one I followed
    reagen likes this.
  6. SwampLedge
    SwampLedge
    I had no upholstery experience at the end of 2023. I bought a Sailrite LS1 machine (that’s it in the background), watched a bunch of YouTube videos, did a new seat for my beat up old golf cart as a practice piece (and sewed a bunch of vinyl scraps for practice, too) and then, in Jan-Mar, did this interior for my ‘28 RPU. The pleated panels started as plain vinyl, to which I stitched 1/4” sew foam. If I can do it, you probably can, too. IMG_1196.jpeg
    Squablow, '29 Gizmo, wfo guy and 12 others like this.
  7. SDS
    SDS
    OK, gave birth to my first door panel today...
    IMG_7227.jpg IMG_7233.jpg IMG_7226.jpg PXL_20240506_185949433.jpg PXL_20240506_185955281.jpg
  8. SDS
    SDS
    Real pleats, done the easy way...
    PXL_20240505_182822868.jpg PXL_20240505_182827347.jpg PXL_20240505_183406896.jpg PXL_20240505_184801690.jpg PXL_20240505_185024724.jpg
    Squablow, brEad, Sandcrab and 11 others like this.
  9. brady1929
    brady1929
    Great job SDS.
    lothiandon1940 and SDS like this.
  10. Sporty45
    Sporty45
    Looks awesome. Nicely done :cool:
  11. Very, very nice job!!!!!!!
    SDS likes this.
  12. SDS
    SDS
    Big kudos to whoever turned me on the Weldwood landau top adhesive. I returned the five spray cans of 3M stuff and bought a gallon of Weldwood and a $20 EZE glue spraygun. This stuff is amazing to work with and stocks like mad. In addition, I've made two door panels and only used about an inch from the gallon can.
    Will never go back to spray cans.
    lothiandon1940, brEad, drdave and 2 others like this.
  13. patsurf
    patsurf
    nev
    never heard of the glue sprayer before!
  14. Flatrod17
    Flatrod17
    What is a EZE glue spray gun? Can you give more info on it?
  15. jakesbackyard
    jakesbackyard
    from ND
    1. Upholstery
    brEad and drdave like this.
  16. Flatrod17
    Flatrod17
    Thank you, I am going to look into buying one!
  17. SDS
    SDS
    I bought both the Weldwood landau adhesive from:
    https://www.yourautotrim.com/ezespg...4judmjpJBrHljw4l7cMOT8zierfLd3hUaAmGjEALw_wcB
    ...and the EZE spray gun from Amazon:
    https://www.amazon.com/EZE-TB-10P-S...15191722&sprefix=eze+spray+gun,aps,135&sr=8-2
    There are no small parts/orifices to become clogged like you get with a paint spray gun. I like the plastic cup, so you can easily see if you're running out. Leave the adhesive in the gun and hang it, the solvent keeps it from drying up.
    jakesbackyard likes this.
  18. SDS
    SDS
    Need advice on the carpet...
    I am not afraid to piece and sew it together with a seam around the trans cover and a few seams over the trans cover, but am concerned about seam allowances making it tough to get a tight fit. Also concerned about the seams being bulky on the back side. I bought jute and can shove the seams down into the gaps between the jute panels, but have been thinking to not use the jute.
    Another option is to make the trans cover carpet as a separate piece with a bound edges...either the trans cover over the edges of the flat floor carpet, OR the flat floor carpet over the trans cover edges. In any regard, I'll also have removable floor mats with bound edges.
    Need some recommendations from guys who've done a few of these.
    Thanks~
    6inarow likes this.
  19. 3quarter32
    3quarter32
    I like the trans cover with the binding on it and separate from the main floor. Good thing is if you have to take the cover off you don't have to remove half the carpet to get to it. I guess it is just what you like the best.
    brEad likes this.
  20. SDS
    SDS
    This guy has good techniques...
    brEad and Sporty45 like this.
  21. Sandcrab
    Sandcrab
    I made a pleated panel for the Devon before I saw your post. That looks great. I have already sewn the upper and lower panel to it, and probably do not have enough material to do it anyway so I probably won't take it apart, but it really puffs up the pleats.
    Sporty45 likes this.
  22. Sandcrab
    Sandcrab
    SDS, one of the guys on allmetalshapers.com uses belting and adhesive and then sews with a large needle and twine to bind any darts or inside corners. That doesn't add to the thickness.
  23. SDS
    SDS
    Use contact adhesive to attach the cover to the panel, glue one section at a time and pull it tight (front only).
    Then, flip over and hand brush the contact adhesive to the back of the panel and the 2" border of remaining fabric. Pull it as tight as you can without tearing, then stick it to the back-side (about a 3-4 inch section at a time). I got a lot of the wrinkles, kinks and pulls out by doing it that way.
    Also, doing it in a warm work area REALLY HELPS versus cold. The vinyl really complies when it's warm.
    brEad likes this.
  24. SDS
    SDS
    Like the second example in this video?
    Looks like a time consuming pain in the keester, but is probably the best method for not adding bulk to the seams.
    Works with flat seams too
    reagen and brEad like this.
  25. SDS
    SDS
    The carpet I am using is loop, not cut pile. The rows of loops are easily visible.
    Do I run the rows front to back, or side to side?
  26. Sandcrab
    Sandcrab
    Yes, but skipping the first hand sew portion and hand sewing the belting to the carpet on each side of the gap.
    SDS likes this.
  27. This is how I did mine. None of the upholstery or carpet has been attached in this picture so its all kind of loose and hanging but it gives the general idea.
    Squablow, safetythird, rod1 and 2 others like this.
  28. ratrod0
    ratrod0
  29. SDS
    SDS
    Carpet day...
    Going to screw down the sill plates, then trim the rest of everything. I've decided to go the route where the firewall will be a separate piece and ty floor carpet will go over the top of the transmission cover carpet and the floor carpet will have a nice bound edge
    Squablow, loudbang and brEad like this.
  30. SDS
    SDS
    The trans cover carpet happened today...
    PXL_20240521_170141355.jpg PXL_20240521_182218768.jpg PXL_20240521_183153194.jpg PXL_20240521_185358142.jpg
    I'll sit the trans carpet out in the sun, so it molds a little, before gluing it to the cover. Will only glue in a few spots and not on the flange in case I need to get the screws out to remove the trans cover.
    Next, have to bind the carpet edges on the hole for the transmission then do the firewall.
    Jeff34, Sporty45, Whoamel and 3 others like this.
