Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    1. Hydro Tech
    Question: can the car do a burnout?
    Answer: 20240103_090341.jpg
    Yes
    Now the exhaust manifold has blown a gasket. That's what I get for abusing the car, I guess...!
  2. PhilA
    PhilA
    1. Hydro Tech
    Raining cats and dogs today.
    Milkshakes occur, nonetheless. Rain isn't a reason not to go places.
    Phil
    1low52, bchctybob, loudbang and 2 others like this.
  3. PhilA
    PhilA
    1. Hydro Tech
    Actual work on the car today. Exhaust had been getting chattery, the weather was pleasant enough today to actually attempt to accomplish something.
    Set the table up and started placing parts of the car on it.
    Pulled the manifolds off. Still looking pretty clean, but the culprit was visible.
    Yup. That'll have been leaking, then.
    Split everything down, cleaned it up, made new gaskets and reassembled.
    Got it all put back together just as the light was fading.
    A quick drive shows it's nice and quiet again, and running more smoothly now the exhaust is scavenging better at idle.
    Phil
  4. PhilA
    PhilA
    1. Hydro Tech
    Went get some storage boxes.
    Somehow big car looks small.
    Sounds like I've got a front wheel bearing going out.
    Phil
    Woogeroo, loudbang, bchctybob and 2 others like this.
  5. PhilA
    PhilA
    1. Hydro Tech
    Tightened up the bearing 1/8 turn.
    That lasted 15 miles.
    Oh well. Time to order bearings.
    Phil
    bchctybob and loudbang like this.
  6. PhilA
    PhilA
    1. Hydro Tech
    Test tonight- up to speed. Into neutral.
    Determine noise is water pump.
    bchctybob likes this.
  7. Pontmerc
    Pontmerc
    from Finland
    There is a great danger, that ford 5000 tractor water pump repair kit fits pontiac pump just fine.
    bchctybob, PhilA and Woogeroo like this.
  8. PhilA
    PhilA
    1. Hydro Tech
    Just ordered a new pump, they should hopefully be in toward the end of the week.
    This is a brand new pump with no core return so I could always use the old one to see if the repair kit fits.
    Phil
    brEad, bchctybob and loudbang like this.
  9. PhilA
    PhilA
    1. Hydro Tech
    Went grabbed dinner. Hid the car in a lineup.
    Heater is working overtime right now.
    Phil
  10. I always love your context photos. Your car looks so massive and has such a great presence, then in comparison to modern vehicles, it still has a great presence, but is definitely not as massive as I think it is. Great documentation of how vehicle design has changed.
    bchctybob, PhilA and TrailerTrashToo like this.
  11. PhilA
    PhilA
    1. Hydro Tech
    Thanks! It's always interesting to see. That lineup made me smile.
    Got some freezing weather coming so I made sure the antifreeze is up to scratch.
    Wouldn't know it though, was 72 today.
    Phil
  12. PhilA
    PhilA
    1. Hydro Tech
    Icicles (small) today.
    Also dressed up for Mardi Gras.
    Started up and idled away happily, despite the wind chill.
    Normally only see that inside a freezer.
    Phil
  13. PhilA
    PhilA
    1. Hydro Tech
    The radio had become all pops, crackles and distortion. So, I wrangled it out from under the dash. Always an enjoyable* experience.
    Took it apart and checked the output tubes. I think the damp had gotten in and corroded the connections, a typical problem with Loktal tubes.
    That brought the sound back so I sat it on the bench for an hour to test.
    Played well enough, which was good.
    I do think I'll get a solid state vibrator for it though, and I'm looking for a replacement loudspeaker that can actually cope with the full output of the amplifier. This one's terrible.
    Phil
  14. bchctybob
    bchctybob
    The glow of vacuum tubes gives me a warm feeling deep in my soul.
    Hillbilly Werewolf and PhilA like this.
  15. Gee Bob, some things we do not need to know:rolleyes:
    bchctybob, Oneball and PhilA like this.
  16. 302GMC
    302GMC
    from Idaho
    Phil, when those cars cost $125, & everyone was going from 8 track to cassette we used to put 20oz Utah 6 x 9s in the Delco radios. Usually had to have somebody stand on the case so we could get the screws started ...
    bchctybob, PhilA and Bleach like this.
  17. BJR
    BJR
    [QUOTE="I do think I'll get a solid state vibrator for it though, and I'm looking for a replacement loudspeaker that can actually cope with the full output of the amplifier. This one's terrible.Phil[/QUOTE]
    My girlfriend got a solid state vibrator and loves it!:p
    bchctybob, '28phonebooth and loudbang like this.
  18. PhilA
    PhilA
    1. Hydro Tech
    My girlfriend got a solid state vibrator and loves it!:p[/QUOTE]
    Highly reliable, I'm told.
  19. PhilA
    PhilA
    1. Hydro Tech
    Car didn't want to start today, ended up adjusting the auto choke a bit and that solved the problem.
    Possibly also needing fuel might have been an issue too. Went fuel up, spent the day assembling furniture then drove home.
    Shortly after I took this photo the speedometer randomly dropped to 0 and the odometer stopped turning. Something quit working, so that's on the to-investigate list. Either the plastic drive gear has stripped or the cable broke, odd that it showed no sign of issues before stopping.
    Phil
  20. PhilA
    PhilA
    1. Hydro Tech
    Fun for an early Mardi Gras parade.
    Phil
  21. BJR
    BJR
    I have followed your thread from the beginning and love what you have done. All the work on the hydromatic and all the work it takes to document it. My only question is your title says Mild Custom. What is custom on your car? Looks stock to me.
    bchctybob and Moriarity like this.
  22. PhilA
    PhilA
    1. Hydro Tech
    Notched and dropped as far as it'll sit down.
    Stock height on these makes them look like a rollerskate.
    Mildly customized interior (hidden under the blankets).
    Like, mild mild.
    Phil
  23. PhilA
    PhilA
    1. Hydro Tech
    Not much to report.
    Been looking at different places through the windshield.
    Country roads.
    Adjusted the throttle-gearbox linkage a touch, got the gears shifting at the correct speeds now. It was hanging on to gears when it shouldn't have been. Real touchy though, an eighth of a turn of the nut is about 15 mph.
    Went to a little meetup in town, that was nice. Got to shoot the breeze with people for a while.
    Speedometer had quit so I pulled the old cable out. Oddly it still turned but the gearbox end had worn away and was round.
    Stuck a new one in.
    Speedometer had resumed service. That's nice to have back.
    Also replaced the rear UJ, the old one was getting noisy.
    There we are, up to date.
    Phil
  24. Out of curiosity how close are you to New Orleans? In a couple years I plan on taking my wife on a road trip to Florida that follows the same basic route my mom used to take when we were kids. And it started driving straight down to New Orleans. Always like the idea of a chance to meet other people from here
  25. PhilA
    PhilA
    1. Hydro Tech
    By road, about 65 miles. To get here, you have to have intention of going here, we aren't "on the way" to anywhere.
    However, if your passing through let me know, it's not too far of a drive.
    Phil
  26. Oh once we get to New Orleans it won't be a rushed trip. Specifically planned to putt along, stop at roadside attractions, and take various detours etc.
    bchctybob, brEad and PhilA like this.
  27. PhilA
    PhilA
    1. Hydro Tech
    Fan belt started making a noise today. Went take a look and the generator mount has cracked.
    Guess I didn't anneal it right.
    Need to pull that all out and weld it up but not today.
    bchctybob, loudbang and Woogeroo like this.
  28. PhilA
    PhilA
    1. Hydro Tech
    Yup, that was definitely broken.
    I didn't have a welding machine when I made it hence the bolts. That and I wanted to adjust it.
    Well, now it's welded.
    Splash of paint and started to reassemble.
    All back together and working properly. Also did oil and grease because it needed doing.
    Just enjoying adding the miles.
    Phil
  29. PhilA
    PhilA
    1. Hydro Tech
    Car was looking a bit unloved.
    Broke out the polishing machine and got busy.
    Phil
  30. PhilA
    PhilA
    1. Hydro Tech
    Went put fuel.
    Now it's dirty again.
