Technical Bending drip rail
Discussion in 'Traditional Hot Rods' started by cpldale, Mar 10, 2020.
  1. 57JoeFoMoPar
    57JoeFoMoPar
    Great work and very useful tip. Taking some of the learning curve out of these common issues that are encountered in a build reduce cost and build time significantly. Love it
  2. Rickybop
    Rickybop
    Thank you. I like to see somebody else do it before I start experimenting. LOL
    A guy on one of the hot rod TV shows bent a piece of stainless trim 90° the hard way with a torch and his muscles. He said it might tear the far side, but it didn't.
  3. scoob_daddy
    scoob_daddy
    from Georgia
    this is great, thanks for the tip!
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Another alternative sans heat would be to bend it in a diAcro or similar bender. I used an old tractor gear as an inner shoe to bend around, when I made a mounting flange for a champ car dash.
  5. The37Kid
    The37Kid
    Old thread, but it has the info I was looking for, Thanks! Bob
    Outback and continentaljohn like this.
  6. continentaljohn
    continentaljohn
    Great information and we use a DiArco for bending our metals 71291FFF-E5DE-49A3-801F-2BEBC421448C.jpeg
    Outback likes this.
  7. cpldale
    cpldale
    from Naples, FL
  8. lostone
    lostone
    from kansas
    Could a guy use the new epoxy glues that they use to install body panels to glue these onto the body ?
    Seems it would be easier to glue it on and getting it to make a water tight seal at the same time.
    I've thought about this as I don't want to run a cloth top....
  9. cpldale
    cpldale
    from Naples, FL
    I'm not familiar with the new epoxy glues. Really can't give you a good answer. Maybe other people will have a better answer for you.
    Good luck
    lostone likes this.
  10. Duke
    Duke
    Yes, would likely work very well with the correct product.
    lostone likes this.
  11. Joel W
    Joel W
    I am needing a passenger side for a PB coupe also
    Outback likes this.
  12. cpldale
    cpldale
    from Naples, FL
  13. cpldale
    cpldale
    from Naples, FL
