I bought this filter many years ago, put it away (lost it), recently found it, and now want to install it on Clarence. Unfortunately the flow direction is not shown on the filter itself or the packaging. My assumption is right to left. Wherein the fuel enters into the center of the stone filter, through the sides of it to the outside, then out the small end. Is that correct?
I don't know the answer, but the way you said would make cleaning the filter element difficult. My mind says the other way ????
The way you have it in the 1st picture, I'm going to say inlet is the small end of the housing. Fuel enters the outside of the filter and exits from the center (inside).
Viper reckon that your image would flow left-to-right, capturing the muck outside the sintered bronze filter (not inside the cone): Interestingly, Earls etc have flow arrows on their filters, but little reference on how to assemble them once you forget. Cheers, Harv
My two cents- I agree with the ones who say to have the flow from the outside of the element into the center. For the ones who say flow from the inside out- doesn't that make it nearly impossible to clean well? if you plan to clean and reuse, why would you want to collect the gunk on the inside of the cone where you cannot clean it out very well? For a clean-and-re-use filter wouldn't you want the gunk on the outside where you can wash and blow it out? from in to out? ...and leave the pores open... if you blast crud from the inside, wouldn't you be embedding the gunk deeper into the clogged pores? I am shopping for a 30 and a 10 micron stainless mesh filter, and a few of the ones I looked at say that you can choose either direction. I can understand that if you plan to dispose of the filtering element, loading it up on the inside would make sense for disposal.. but...if you blast it clean, wouldn't you want to blast the gunk out and away instead of deeper into the pores ... ?
GUYS...those sintered filters are NOT...cleanable / reusable !!! At least not properly ! JUST like the same style filters in the various carburetor inlets, they are MADE TO BE THROW-AWAYS. If you've ever rebuilt an older carburetor, they always had a fresh filter in the kit. That is until the paper filter came to be. Less money to manufacture. Sintered filters are...throw-aways when dirty enough to hamper good fuel flow. Mike
I always just cleaned em, blew them out with air afterwards and put em back together. Did it for yrs, I even hated it when they became hard to buy OTC. Agree, flow outside in. .
Well; thanx folks. I guess my logic just doesn't hold up. I'll install little end to the pump and big end to the carb. And for what it's worth I never considered the elements to be cleanable. I thought you threw one away and replaced with new. Of course since this is the 2nd filter in the system (another where gas leaves tank) I doubt the element will ever be dirty.
