Hot Rods Front Engine Dragsters of the 50's
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, May 5, 2022.
  1. Marty Strode
    Marty Strode
    One of the best, Kent Fuller, heated and bent 4130 tube around a car wheel, this is one of his from '68. IMG_9569.JPG IMG_9570.JPG
  2. Dave G in Gansevoort
    from Upstate NY
    How did he keep it from collapsing? Was it packed with dry sand? And finally, how did he weld his chassis?
    My friend and mentor and erstwhile driver, Jim was a fabricator. I know he built one dirt car chassis out of 4130, and gas welded every joint, as recommended by the FAA for small aircraft. He said the heat affected zone was quite a ways from the actual weld, which helps prevent fracture at the joints.
  3. Gary Cagle--Cagle & Herbert---Top Speed 1959 March Meet 180.36. First and only car to run 180 at Bakersfield in '59.
  4. Speed Gems
    Speed Gems
    Here's a couple @40ragtopdown posted in the Traditional Images thread.
  5. Speed Gems
    Speed Gems
  6. Marty Strode
    Marty Strode
    I am sure he gas welded his chassis until 64 or 5, then switched to tig. I will ask Marlo Treit if he used sand, as he was dealing with Fuller back in those days.
    Hamtown Al likes this.
  7. Dave G in Gansevoort
    from Upstate NY
    Thanks Marty.
  8. Speed Gems
    Speed Gems
  9. Speed Gems
    Speed Gems
  10. Speed Gems
    Speed Gems
  11. Speed Gems
    Speed Gems
  12. dreracecar
    dreracecar
    from so-cal
    Because the cage tubing was a whole lot thicker the the rest of the tubing used in the chassis
  13. Speed Gems
    Speed Gems
  14. Speed Gems
    Speed Gems
  15. Speed Gems
    Speed Gems
  16. Speed Gems
    Speed Gems
  17. Speed Gems
    Speed Gems
  18. Speed Gems
    Speed Gems
  19. Speed Gems
    Speed Gems
  20. Speed Gems
    Speed Gems
  21. Speed Gems
    Speed Gems
  22. Speed Gems
    Speed Gems
  23. Speed Gems
    Speed Gems
  24. Speed Gems
    Speed Gems
  25. Speed Gems
    Speed Gems
  26. Speed Gems
    Speed Gems
  27. Speed Gems
    Speed Gems
  28. Speed Gems
    Speed Gems
  29. Speed Gems
    Speed Gems
  30. Speed Gems
    Speed Gems
