vintage supercharger
Discussion in 'The Hokey Ass Message Board' started by pony shaker, May 6, 2011.
  1. pony shaker
    pony shaker
    from washington
    I can't find any info on this. Can any of you guys steer me in the right direction?
    Mikus Maximus likes this.
  2. mart3406
    mart3406
    from Canada
    It's a stock GMC/Detroit Diesel piece.
    Not necessarily 'vintage' either. It's for
    a 53-series Detroit and by the looks of it,
    I'd guess, probably for a inline 4-53 or
    possibly, maybe, a V-type 6V53. They're
    nice little blowers, but compared to the
    bigger '71 series' blowers, they're a lot
    harder to adapt to use as a supercharger
    because there aren't any *commercially
    available* intake manifolds or belt-drive
    set-ups for them.
    Mart3406
    1971BB427 likes this.
  3. pony shaker
    pony shaker
    from washington
    Thanks. It is the 4-53. I've been searching for "arrow" due to the logo in the casting but came up empty handed
  4. Deuces
    Deuces
    With only 2 hold down bolt holes??? Yikes!
  5. 4-53, you will find several threads if you search. I had one and sold it to another HAMBer last year.
  6. 2 bolts fron and 2 rear, they go through the endplates.
    gimpyshotrods and Mikus Maximus like this.
  7. You will also have to rig up an oiling system for the bearings on these. Not sealed like the bigger Detroits.
  8. Mikus Maximus
    Mikus Maximus
    from SoCal
    My 6v53 has a longer case and some other difference from that 4-53 blower. I do have on it a new aftermarket parts from Joe-Blow's Speedshop in Australia. I still have a bit to go on the completion of the rebuild.
  9. fabricator john
    fabricator john
    from venice fl.
    ohio george ran one of those ,, on a sohc ford in his 33 willys ,, built that model kit at least 3 times lol
    fabricator john
    miss you dad
  10. Sorry but you are incorrect. Ohio George ran a pruned 6-71 made of magnesium. Basically a standard GMC with the mounting flange milled off and bolted down from the inside of the case. He went in with Sneaky Pete Robinson and cast 200-300 cases. They also made magnesium bearing plates.
    427 sleeper and Fordors like this.
