Technical Old Crower Rockers SK CH 1003
Discussion in 'The Hokey Ass Message Board' started by BOSTONCAMARO, Apr 27, 2022.
  1. Hello All,
    Not sure if these are from the 60's?
    Are they Pontiac? Are they SBC? If so are they a direct bolt on to heads that were set up for screw in studs?
    I appreciate the insight, my dad who passed 7 years back, had these in a box - he was a hardcore Chevy guy, I still am.
    Thanks in advance, Tim
  2. lostone
    lostone
    from kansas
    Pedestal mount so not pontiac or chevy.
    SS327 likes this.
  3. drtrcrV-8
    drtrcrV-8
    Could you provide other views(Bottom, end, clearence between the mount & the rocker)?
    egads likes this.
  4. I will get some more pics, thanks
    egads likes this.
  5. Jmountainjr
    Jmountainjr
    Also with the offset rocker on each pair the valve spacing is wider than the pushrod / lifter spacing.
    BOSTONCAMARO likes this.
  6. egads
    egads
    Have you called Crower?
    SS327, BOSTONCAMARO and X38 like this.
  7. Not yet, only came across these last night - after business hours, I will call, thought someone here may know
  8. I grabbed a random SBC head I have drilled for screw in studs, all lines up perfectly, pushrods etc - so thinking I have my answer
  9. lippy
    lippy
    from Ks
    Looks like something for a Brodix head? Offset rocker and all.
  10. seb fontana
    seb fontana
    from ct
    No, the off set is to move the pushrod over for big [wider] Int ports.
    Look like bolt on stand and shaft rockers to me?
    Jmountainjr likes this.
  11. egads
    egads
    Did you ever get any info on these?
  12. Still looking for info, appreciate any insight
