I'd like to 'age' or 'distress' this VIN tag which we have had to put on my car for registration purposes here in Japan. Any suggestions on how I can do that? Thanks Pete
salt water probably would do fine would be easier to do before installing it though. Are you looking to keep the surrounding metal clean?
It will get ugly quick enough as it is, "aging" it artificially could eat the aluminum to where the stamped number isn't legible.
Leave the car outside, under a tarp, for a couple decades. That should do it. (sorry...I couldn't resist)
A diluted mix of Lye and table salt in water [5% each] Soak it into a sponge/rag and place it up against the alloy .[keep it wet] I have also had great success adding patina to alloy wheels with dry powder from a fire extinguisher
Thanks for the laugh Squirrel. For those that missed it here she is the day the previous owner Jay, found it and the tarp came off it after 20+ years. If only the tag was on it then Yeah, nah. That's not in the cards for this one. Cheers! Dont think I'll get a dog to piss on it either @blowby
A friend of mine refinishes antique furniture and uses regular bleach on aluminum and decretive tins to achieve the look of time, he sprays bleach directly on the piece he is working on and the sit's it out side in the sun, it will fade the piece, check it every now and then to ac==get the look you want. HRP
Is that the number on your title? That's a fairly early '32 serial number. 1934 number should be 18-450,000+.
For US production the 1934 Ford did not have a VIN tag. They used the serial number stamped into the top of the frame near the steering box (it may be faint). The same number also appears on top of the frame rail under the body where you need to pull the body to see it. Here is a site with a lot more info on serial numbers (thank you Mac VanPelt). The tag you have looks like something from EBAY. If the inspector is knowledgeable showing him a VIN (or serial number) tag when there shouldn't be one will probably get you off on the wrong foot. Charlie Stephens
