Contest:STUMP SQUIRREL!
Discussion in 'The Hokey Ass Message Board' started by Richard D, Nov 28, 2006.
  1. When did the Gilmer belts for superchargers come around?
  2. Wutteryasmokin?
  3. Everyone knows those are sail squirrels!
  4. Bar Ditch
    Bar Ditch
    from Tacoma
    Where can I get hyperutectic piston return springs at?
  5. guys leave squirrel alone need his help on my thread .. thanks .
    Cooon likes this.
  6. chrisntx
    chrisntx
    from Texas .
    It sounds like someone used the chevy firing order instead of Ford
  7. daddio211
    daddio211
    When snow melts where does the white go?
    Hey, its technical!
    ekimneirbo likes this.
  8. Speed Gems
    Speed Gems
    druss32 said:
    What would the correct ignition timing be on a 1955 Bel Air Chevrolet, with a 327 cubic-inch engine and a four-barrel carburetor? ;)
    Wrong!
  9. Jones St.
    Jones St.
    What Wall St. investments (besides the JAB Co.) are paying good returns presently? And will a 283/327 build be a featured thread soon?
    Baumi likes this.
  10. Speed Gems
    Speed Gems
    Why do we park on driveways and drive on parkways? Oh, tech questions...Sorry!
    hotrodjack33 and Hollywood-East like this.
  11. stanlow69
    stanlow69
    Why did the carb on my engine(427) stick on full throttle when I tried to race it when I was 16. Had to pull the wire on my coil to shut the motor down. It diesel`d a bit, but the motor finally shut down.
    chryslerfan55 and hotrodjack33 like this.
    All hail squirrel !!!!
    Petejoe and hotrodjack33 like this.
  13. Truck64
    Truck64
    from Ioway
    Way back on pg. 1
    Technically speaking, Paul Revere apparently didn't own a horse. I looked it up.
    He borrowed a horse for his famous midnight ride. The guy he borrowed it from, had borrowed it yet from somebody else. The name of the horse hasn't been conclusively established from the historical record, although "Brown Beauty" is a contender. It is said that the horse was not returned.
    (Jim of course naturally knew all this, and more, I'm just saving him the drudgery of having to type all this stuff out).
  14. Torana68
    Torana68
    from Australia
    Must be a slow week for you guys over there.
  15. twenty8
    twenty8
  16. choptop40
    choptop40
    is a pisston a bladder problem ???
    hotrodjack33 likes this.
  17. Truckedup
    Truckedup
    Silly nonsense in my opinion. With Google ,the Internet, a person who's been on this site for 15 years could answer just about any question .....
    The real knowledge comes from working on and building vehicles..Jim (In NJ a Squirrel was derogative term for a wanna be street racer) has built car/engines for years and does a great job with drag racing them....But by his own admission knows less about old hot rods than many guys here...
  18. cfmvw
    cfmvw
    "If you can call an orange an orange, why can't you call a banana a yellow? Blueberries I can understand, but I wish someone would explain gooseberries to me sometime!" - Jim Ignatowski
    hotrodjack33 and bchctybob like this.
  19. Dangerous Dan
    Dangerous Dan
    Did Debbie ever make it to Dallas..?
  20. 5window
    5window
    So, we have tree squirrels and flying squirrels and 13-lined ground squirrels (the wonderfully named Ictidomys tridecemlineatus) but what is a stump squirrel?
  21. blowby
    blowby
    from Nicasio Ca
    Why did Chevy run the distributor through the intake manifold?
    seb fontana and hotrodjack33 like this.
  22. hotrodjack33
    hotrodjack33
    Apparently, @squirrel has left the building;)
  23. squirrel
    so they'd be in oil, and wouldn't get stuck like Ford distributors?
    40two, Baumi, Budget36 and 10 others like this.
  24. Truckedup
    Truckedup
    Why do the last few years of the Chevy inline 6 have u joints on the HEI distributor shaft?
  25. blowby
    blowby
    from Nicasio Ca
    The judges have accepted your answer. You remain unstumped.
    kidcampbell71 and Budget36 like this.
  26. squirrel
    It's really probably because it was easier to make it that way.
    hotrodjack33 and Truckedup like this.
  27. blowby
    blowby
    from Nicasio Ca
    I like the first answer better. As you can see, the surface around the distributor in front of the back wall is lower, which would allow oil in. It would have been just as easy to run the wall around the front looks like.
  28. seb fontana
    seb fontana
    from ct
    Isn't there an oil passage that bisects the dist bore needing a groove in the dist housing? Maybe back wall lower towards front to keep oil in the block?
  29. GMC BUBBA
    GMC BUBBA
    Sure engineering wise !!!!
    1-how many drops of oil are in a qt ???
    2-how much is burned on every compression stroke ….??
    3-if you drop one drop every 50 ft how many miles to lose a at ????
    Answers are all covered in a gas engine film from ford in the 60s !!’nnnnn
