Very well engineered interior. I love the how cowl steering allows the driver to sit low in the car. Sweet!
Those look a lot like the ones I tried in my pickup. I loved the seats, they feel great; but I hated the lost leg & head room. Too thick. You have a little more room in your coupe, I'm glad they worked well for you. They look good.
1996 Toyota Previa DX rear seat. It slides and folds: slides forward 5”, folds forward to 45 degrees and fully reclines. Fits perfect in my 29 and provides easy access behind seat.
Ended up using seats out of a Mini Cooper, just fit, gives good support. IMHO, more comfortable than a Caravan seat
Pretty sure that is a Jeep Wrangler YJ, '87-'95, rear fold and tumble seat. I had one for a little while. The Jeep rear floors are flat so the mounts should be easy to adapt to a Model A. I believe there is also a fixed rear seat with the same dimensions on the lower optioned models.
Used a 90's Caravan seat in mine. Cut 6 inches out of the middle and made a platform that it mounts to out of 1" x 1" tubing. Did my own upholstery for the first time.. The back also folds down. Have space to stash things underneath and its comfortable enough for most cruising. I'm 6 feet tall and fit pretty well even with the top up.
