Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    OK
    Next item: Call me crazy but is the slider bracket crooked - twisted clockwise? Or is it one of those camera lens things?
  2. No it's cooked I'll align it once I have the braces made. .5 deg out
    D-Russ and loudbang like this.
  3. Finished the bracing today 20211201_165452.jpg 20211201_165452.jpg 20211201_165440.jpg
  4. Well I finished up the front end today. Bolted in, aligned, painted and spindles installed 20211207_124551.jpg 20211207_124558.jpg 20211207_124614.jpg 20211207_153257.jpg 20211207_153315.jpg
  5. One thing about LSR, not a whole lot of worrying about vehicle weight.... LOL.
    Stogy, Just Gary and loudbang like this.
  6. Weight is our friend lol
  7. Now I just need to paint the underside of the frame, man the salt just eats the hell out of everything
  8. jimmy six
    jimmy six
    What do your think about your trailer and truck? Rust never sleeps.. I can no longer afford to sacrifice trucks to the salt Gods…
    chryslerfan55, Stogy and loudbang like this.
  9. Both truck and trailer have issues as well. Had a brake line rust out just before heading to Bonneville in 2020 there is no stopping the rust completely even though I try..
    Stogy, loudbang and Just Gary like this.
  10. And we had to redo the brakes on the trailer and the trucks trailer brake controller in preparation for 2021.
  11. SilverJimmy
    SilverJimmy
    I am amazed at the amount of rust on your truck. I have a Suzuki Samurai that I’ve taken to Bonneville over 10 times since 2008, we drive it everywhere on the salt, and it’s rusty, but it’s mostly surface rust. When I get home it usually has a thick layer of salt covering everything that the spray from the tires hits. All I do is wash it with the garden hose for about an hour. But I do live in Arid-Zona and our normal humidity is low, so maybe the Salt Monster needs a drink to really eat?
  12. I also live in a high desert environment. When we get back the truck gets several hours with a low pressure sprinkler. Moving it around once you see the water run clean in one area. Like below
  13. The new stance for the 640
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  15. John, that looks AWESOME!:cool:
    seadog, loudbang, Dino 64 and 2 others like this.
  16. old flopper
    old flopper
    That’s low enough to pickup new fans from a low riders club. :D
    loudbang, D-Russ, Dino 64 and 2 others like this.
  17. I will Raise it about 1"
    Once the engine is back in to center the shock travel but it's still going to be low.
    Who knows it might be better for aero, just won't know till we try it on the Salt.
  18. For those about to rock, we salute you.
  19. Just wanted to take time to wish everyone happy Holidays this Christmas and New Year and please remember the reason for the season.
    May God Bless us all
  20. Right backatcha!
    chryslerfan55 and Just Gary like this.
  21. Got the front end reset to a reasonable stance today it will drop about an inch once the engine is in 20211216_160116.jpg
  22. Setting the Toe to 1/8" toe in the old akool way.. 20211217_114611.jpg
  23. saltflats
    saltflats
    from Missouri
    Whole new attitude, looks good.
    fegsta, Stogy, loudbang and 1 other person like this.
  24. I had to clearance the wishbone mounts for the tie rod bar for when the wheels were turned it 20211218_144507.jpg 20211218_144457.jpg didn't make contact
  25. Just saw the 2022 ECTA standing mile schedule April 22nd through the24th. Better get on the ball..
  26. fegsta
    fegsta
    Hello John, I see you use split pins or cotter pins, so how much safety wire do you use. Do you have to wire header bolts and the likes, Regards tim.
  27. It's not required in my class although it's not a bad idea.
    I haven't had any issues with header bolts coming loose but the truck gets torn down after speed week and everything gets a nut and bolt inspection after every run.
  28. I took the cylinder head up to Jimmy's today, cleaned it up and did a close inspection. Jimmy and I will do some flow bench testing to see if we can improve the head a bit more.I may mill another .020 to .030 off the head for some more compression. I need to find more power somewhere..
