Technical Synthetic Oil verses conventional motor oil.
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Nov 30, 2021.
  1. I drove my '32 to the auto parts house yesterday to get some antifreeze for my daughters car and I got into a conversation with a old friend that works there and naturally we started talking about our cars, he was telling me he is building a new engine for his '55 Chevy and he is planning on using synthetic oil.
    I'm from the old school, if my motor oil works why switch to something new?
    Is there any advantages/disadvantages of these new age oils? HRP
    Desoto291Hemi likes this.
  2. Joe Travers
    Joe Travers
    from Louisiana
    More miles between changes......
    Joe
  3. saltracer219
    saltracer219
    Synthetic oil works just fine, but one thing that I have found to be true is that the way early engines are sealed they have a tendency to show leaks more with synthetics than then they do with conventional oils.
  4. RAK
    RAK
    Break the engine in with a mineral oil then switch to synthetic. Rings may not seat with synthetic because it's too slippery. After break in Mobil 1 15w50 has all the zinc you need for an older engine, used it in my flathead without any problems for years.
  5. 210superair
    210superair
    from Michigan
    IMHO, Run whatever has been run in an engine. I don't switch up unless it's a fresh motor. I stick with whatever it's had in it previously usually. I've never run synthetic in any of my old stuff.
    WB69, F-ONE, egads and 1 other person like this.
  6. RedRoan89
    RedRoan89
    My dad has been a "lubrication technician" for about 20 years now, and no its no a oil change monkey. He's been overseeing any and all lubrication in a factory, from hydraulic systems, back up generators, pickup trucks to small engine driven welders. He has to go to special classes about twice a year to keep up with whats new in the world of oil. I have had MANY conversations with him about oils, oil filters, oil change intervals and oil samples. Obviously he can be very technical with thw subject, but I can convey some of what he has told me. If you've been running conventional oil for 100,000+ miles, continue running it, if you have 10-15,000 on a fresh build, run whatever you want. The synthetic oil has a extended service interval, but he says it has added cleaners in it also. I do know that is the only thing he runs in everything he owns, tractors, lawnmowers, generators, cars trucks everything. If you happen to have a specific question, I'll be more then happy to ask him and get back to you
    Hnstray, AHotRod, ffr1222k and 5 others like this.
  7. pwschuh
    pwschuh
    RAK is right. Definitely benefits to a quality synthetic, just don’t use to break in.
    WB69, 61 Fairlane, loudbang and 3 others like this.
  8. okiedokie
    okiedokie
    from Ok
    My experience with synthetic oil happened several years ago. I drove my 40 to a friends house about 30 miles away one Sat. During the next week I switched to synthetic oil. Just by coincidence I drove it the next weekend back to the same friends house. Both days 100 degree temps. After the synthetic the engine temp was 12 degrees less than the the temp with non synthetic oil.
    AHotRod, dirt t, loudbang and 3 others like this.
  9. TA DAD
    TA DAD
    from NC
    New cars come with synthetic oil so I don't see ring break in a issue.
  10. Truck64
    Truck64
    from Ioway
    New cars use different ring materials, and also different cylinder surfacing than old school iron though.
    Synthetic motor oil technically speaking is much superior to conventional motor oil, and it isn't even close. Use it if it makes you feel better, I've never felt the need in an ordinary stock carbureted engine with 20th century bearing clearances and the rest of it.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    An advantage to 0w20 synthetics seems to be nearly constant viscosity with temp. Fast idle on a fairly fresh 21-studder, ~20psi cold, warm & hot. Better than 20w multivisc that flows and pumps like molasses when cold.
    AHotRod, HOTRODPRIMER and Truck64 like this.
  12. squirrel
    They seem to not have conventional house brand oil at walmart any more, and besides the cost difference was negligible...so I'm using synthetic in the old cars now, too. I've been using it in the modern cars since my wife finally stared buying modern cars just over 20 years ago.
    I run it till the change oil light comes on in the modern cars, which is about 8k miles...and it's up to about 5500 on the last oil change in Plan II. I think I need to change it soon in that one.
  13. 210superair
    210superair
    from Michigan
    What about synthetic in flatheads? I've never heard that discussed. No issues?
  14. 5window
    5window
    My Walmart still carries two types of conventional 10-30.
    HOTRODPRIMER likes this.
  15. HOTRODPRIMER likes this.
  16. THANK YOU, Sir.
    Ben
    WB69, Deuces and HOTRODPRIMER like this.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    And here I thought it was another California took it away thing.
    Well, just like Home Depot told me once. "If it doesn't sell we put something else on the shelf that will".
  18. moparboy440
    moparboy440
    from Finland
    Look at how many people who have had flat tappet cam failures lately. The main reason for this is that they have been using modern Zinc free Synthetic oils.
    One oil is not better than another, it is about choosing the right oil for the application.
    mad mikey and HOTRODPRIMER like this.
  19. moparboy440
    moparboy440
    from Finland
    All new cars come with aluminium blocks with sleeves. You can't compare that with an old iron block.
  20. CNC-Dude
    CNC-Dude
    That's true! Most all car manufacturers around the world have been using synthetic oils in new cars for almost 15 years now, both gas engines and diesels....So the "break-in" quandary really isn't one!
  21. Flat tappet cam failure reasons.
    1: crappy made lifters.
    2: crappy made lifters
    3: improper adjustment
    3: crappy made lifters
    4: low zinc
    Oil is good. I recommend using it.
    Change it a time or two.
    Avoid orange filters if possible.
  22. rusty valley
    rusty valley
    Hard to find regular oil on the shelf here, its mostly "synthetic blend", whatever that is.
  23. CNC-Dude
    CNC-Dude
    Maybe in Europe where the cars are typically smaller than here in the US. A lot of our car and truck engines are still cast iron.
    427 sleeper and HOTRODPRIMER like this.
  24. TA DAD
    TA DAD
    from NC
    The cylinder sleeves are made out of what ?
    AHotRod, Beanscoot, RICH B and 4 others like this.
  25. MeanGene427
    MeanGene427
    from Napa
    Had a similar experience in 2002 with my Indian (S&S engine). It's warmed up some, makes 97hp at the rear wheel from 88ci. Went to Mobil 1, and the oil temp dropped 10 degrees, and I actually had to lower the idle RPM, it idled faster with the syn. I also put Mobil 1 gear oil in the new 6-speed I installed, and it started shifting soooo smooth
  26. squirrel
    that's odd, my car ran slower on Drag Week this year with synthetic, than it has in the past with normal oil.
    perhaps there is more than one variable at play, here.
  27. XXL__
    XXL__
    Indeed. Barometric pressure, air/track temp, tire pressure...
  28. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Stated a couple of times above but, yes, regular oil getting scarce in my neck of the woods too. "Synthetic Blend" and full synthetic is pretty much all I can find.
  29. Torana68
    Torana68
    from Australia
    done a leak down test with both oils?
