Technical Kanter Auto Products
Discussion in 'The Hokey Ass Message Board' started by Karl_William, Nov 25, 2021.
  1. Stooge
    Stooge
    I bought one of their deluxe front end rebuild kits for a '58 Edsel Villager wagon im working on, and am planning on going through them for the front of my '37 Buick. I'd say 90% of the kit for the Edsel was correct, with the exceptions being the front sway bar bushings, (though they sent universal link ends/ bushings that im using on another truck so i cant complain) and they sent staggered sets of lower control arm bushings, a big and little inner diameter, where the wagon uses 4 of the same ones, ( 2 out of the 4 fit, and needed 2 replacements). I emailed a couple times, but it was early last yr when all the pandemic stuff was just starting so i figured it was lost in the shuffle. For an oddball car, and where the correct, replacement parts were short money and easily available, im still happy with them and will use them again.
    Karl_William and lothiandon1940 like this.
  2. texasred
    texasred
    from Houston
    they are a top rated advertiser in Hemming Motor News for over 40 years, I have used them countless times with no problems
    lothiandon1940 and Karl_William like this.
  3. Beanscoot
    Beanscoot
    There was mention of this in another thread a couple days ago, in which someone questioned if the pistons were sourced from Egge. The poster thought that the Egge pistons gave a really low compression ratio.
  4. seb fontana
    seb fontana
    from ct
    Not the same as a 410MEL.
  5. Northern is who I use. The owner has been a member here
    Truckdoctor Andy likes this.
  6. I did not realize that. Is the 410 the same family as the 430? When did that family go out of production?
  7. I love Northern. Always great prices and great parts.
    Tman likes this.
  8. FrozenMerc
    FrozenMerc
    I will 2nd Northern Auto Parts. Just bought a Master Rebuild Kit for a non-Hamb friendly IH 6.9 IDI. Good Parts, Great Service, and reasonable prices. They are my go-to choice for rebuild kits for odd motors.
    Kanter is also a great company. I have bought a ton of Packard parts from them over the years. That said, check the pistons closely in the kit. I have never seen an Egge, Kanter, or anyone else provide a replacement MEL piston that matched the stock units. Most of the time, they come with generic flat tops that will significantly reduce compression and kill combustion performance. A custom piston is the only option, however there are a number of companies that will provide excellent custom pistons these days for a reasonable amount of cash.
    Ford made 2 different 410 motors.
    1958 MEL 410. One year wonder used in Edsel's only. Labeled as an E-475, 475 ft-lbs was the peak torque rating. It was essentially a de-bored 430. MEL's went out of production in 1968. Replaced by the Lima 385 series (429 / 460) of V8's.
    1966 and '67 FE 410: Two year wonder used in Mercury's only. Essentially a 390 with a 428 crank.
  9. 57Fury440
    57Fury440
    I've used them a few times with no problems.
  10. Budget36
    Budget36
    Kanters. The first place I found searching the internet, mid 90’s with AOL.
    Nothing else to add:)
    Bill's Auto Works likes this.
  11. cabong
    cabong
    Ya can't go wrong, especially when on many parts they are the only game in town. I've been buying parts, especially front end kits for over 50 years, the last one being within the last year.
  12. The only Thing they are a little over Priced but they have
    what you want, they been Advertised on Hemming's for as long
    as The Wheel has been Around.!
    Just my 3.5 cents
    Live Learn & Die a Fool
  13. I forgot to say that Rock-Auto has about the Same Parts at a Big Different
    in Saving a lot of Money.!
    Just my 3.5 cents
  14. Bearing Burner
    Bearing Burner
    from W. MA
    As I remember Kanter started out as Packard parts and then expanded to other brands. Been in business for a long time.
