Hot Rods Powerglide transmission question
Discussion in 'The Hokey Ass Message Board' started by Deano61, Nov 17, 2021.
  1. Deano61
    Deano61
    What supports run off the midplate for a direct drive powerglide transmission for dirt track racing?
  2. saltflats
    saltflats
    from Missouri
    :confused: Not sure I understand what you are asking.
  3. MAD MIKE
    MAD MIKE
    from 94577
    You've been here since '07 and have yet to unlock the Carnac App?
    Shame.
    :p :D
  4. The upper franistat should nave a knurdling pin restractor
    loudbang, saltflats, Hnstray and 2 others like this.
  5. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Powerglide 2speed tranny have been used for racing for a long time.
    Not really knowing what the Q,as it was not layed out well.
    I'll rambull some.
    Back in the late 1970s Winters Performance put out a kit to build your own for dirt oval racing.
    I got the kit and built my own,but I was racing on blacktop,not dirt,an my Latemodel Mod was making well over 400hp. So it took me 9 race weekends too redesign one to work on blacktop with big HP n 10in. wide rubber,brake it an fix next week point for 8 times.
    Something TCI never could do.
    The clutch pedal,I hooked to a 1/2in. ball valve,to control pump PSI that I made to 160. I redesign valve body and size of servo feed lines. The Winter's drive to replace T-C was the only thing not needing big mods. Even the alum PG case had to be reinforced. The drive was this design.
    https://www.ebay.com/itm/234178596052?
  6. lake_harley
    lake_harley
    dana barlow likes this.
  7. MAD MIKE
    MAD MIKE
    from 94577
    Was that in the Retro-Encabulator or the Turboencabulator... or was that the Entabulator?
    It's been a while since I've surmounted my two spurving bearings... but that might be a personal problem.
    dana barlow, saltflats and Hnstray like this.
