Technical Keeping the windshield from fogging up
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 29, 2021.
  1. Driving during the winter an d with the temperatures being cooler I am constantly wiping the windshield to keep it clear, especially when its cool and raining, much like today, my car lacks defrost and I have been looking for something to alleviate the occasional problem.
    As I was researching alternatives I ran across this item, of course it is from the much maligned harbor freight, but it's cheap, works off a 12 volt accessory plug in and might just do the job.
    Have any of you guys used anything like this in the past? HRP
    12v Auto Defroster With Light
    Truck64 likes this.
  2. Truck64
    Truck64
    from Ioway
    I think maybe Rain-X applied to the inside helps with that. Or spit, like we did when snorkeling!
  3. goldmountain
    goldmountain
    I have no experience with that unit, but here in Canada, defrost is not really an option. However, I have always wondered how the Model A guys run defrost with that gas tank there.
    HOTRODPRIMER likes this.
  4. G-son
    G-son
    from Sweden
    Have not used, but in general, you need a ridiculusly large current to make any significant amount of heat with 12V. If it uses 10A for example it gives of just 120W, not much compared to proper electric heat fans for your home and such, pumping out up to a few thousand watts.
    In a car the absolutely most sensible way to get heat is to use the waste heat in the cooling system.
  5. On my '35 pick-up I open the windshield a bit and crack a door window open.....keeps the windshield clear, but it gets a bit chilly in the cab......if you have a heater, run a flexible duct from it to the windshield.....
    VF-1 and HOTRODPRIMER like this.
  6. I use Rain X anti fog.
  7. Casey Riley
    Casey Riley
    from Minnesota
    Polish the glass with Barbasol Shaving foam. The classic one, not the one with aloe.
  8. RainX
  9. Mr48chev
    Word is that those HF units do have a seriously high amp draw. Here as where Goldmountain is a working defroster really isn't an option and is a must have if you plan to drive in cooler months.
    Still for short term use for just a few minutes to keep the windshield clear it might work fine.
    HOTRODPRIMER and mitch 36 like this.
  10. ***Area-51***
    ***Area-51***
    from Ohio
    HRP, tried one of those few years back ( looks like the same one as I remember).... it was nothing to brag about.
  11. BamaMav
    BamaMav
    from Berry, AL
    I think the answer is airflow across the glass more than air temp. I have had vehicles with modern AC units where the ac went out you were still able to blow air on the windshield and keep it somewhat clear. I've had good luck with those "turbo" style summer fans,they look like a tube, placed where it will blow across your vision site. Not as good as a dedicated defrost with AC demist, but better than nothing.
    bchctybob, HOTRODPRIMER and squirrel like this.
  12. No heater. HRP
  13. Jalopy Joker
    Jalopy Joker
    Lots of dash plug in styles but designed for later model dasboards - plus, only focus on one area - Rain X defrost cloth better than nothing - one reason stopped using my '34 Plymoth sedan as commute ride - even high end ac/heat systems defrost have not worked well - need two peole to keep windshield wiped down - will watch here for gauranteed solution
  14. squirrel
    Modern cars with AC, use the AC to dehumidify the air, and it really works great to defog a windshield. Just a heater, works, but not nearly as well.
    I've put a fan next to the windshield on a couple that didn't have real defrosters, and it works pretty well. The blower for a boat bilge is what I used. It's ugly, but hey, that's life.
  15. bill gruendeman
    bill gruendeman
    Air flow is the key. When I snowmobiled even in sub zero temperatures sometimes you had to open the face shield to get some air flow and defog it.
    Alaska Jim, HOTRODPRIMER and SS327 like this.
  16. PhilA
    PhilA
    1. Hydro Tech
    Yeah, those plug in heaters are less than useless, in all honesty. You might as well just eat a can of baked beans the night before you go driving.
    Ultimately if the dew point is low enough, movement of air across the screen will cause the condensation to eventually evaporate, but if you hit a cool patch you've only got a few options- a rag, drier air (air conditioner) or a temperature differential to put the air next to the condensation above the dew point.
    There's not a whole lotta space up under the dash, I know, but possibly look for one of the circular units like a Smiths or Clayton that plumbs to the vehicle's cooling system- idle a while and get a bit of heat in? Those were a popular fitment during HAMB-friendly years.
    Phil
    XXL__, HOTRODPRIMER and Cymro like this.
  17. oldiron 440
    oldiron 440
    Just run with no glass...
    Blues4U, winduptoy, HotRod33 and 4 others like this.
  18. BamaMav
    BamaMav
    from Berry, AL
    That is the same design fan as I was talking about. They move much more air than the larger diameter cooling fans. I bought mine at a truck stop.
  19. KevKo
    KevKo
    from Motown
    Had one like that in my truck when I got it. Basically useless. And I tried Rain X Anti-fog. Wasn't happy. Put in an old Ford heater and ran defrost tubes. Slow but worked.
  20. Cold ,wet,damp and raining, that just don't cut it. HRP
    bchctybob likes this.
  21. oldtom69
    oldtom69
    from grandin nd
    Man,you guys are young!!!I remember most buses and trucks had fans mounted on the dash to keep the windshield clear!Looked like a small [6 inch dia]house fan.would see them in cars too in this part of the country. I'll let some other old timer explain stick-on "canadian windows"
  22. That's as close to having air-conditioning I have ever had in any of my cars. When I pointed it at the windshield, it then became the defrost unit. Mount them up high so they can do both jobs. You can buy ones that also oscillate, so it feels just like one of them new-fangled new car air-conditioners!
  23. goldmountain
    goldmountain
    Those things were called "frost panes". They were oval clear plastic panels that captured an air pocket between it and the glass. I'm sure I haven't seen one on a car for over 40 years now. Heaters are designed better now.
  24. goldmountain
    goldmountain
    Actually, the real Canadian option is to just put away the car until spring. That is sometime in July.
    VF-1, bchctybob, HOTRODPRIMER and 6 others like this.
  25. 210superair
    210superair
    from Michigan
    Boat blower! Nice!
  26. rockable
    rockable
    Vintage Air can help you on the cold and the warm front.
  27. Cymro
    Cymro
    Crack open the vent windows, Rain x , Shaving foam (helps to a certain degree as does a clean windscreen) Wales is wet, I did once have an accessory fan that attached to the screen with suckers no heat, but the airflow helped clear the screen.
    bchctybob, HOTRODPRIMER and Stogy like this.
  28. Kiwi 4d
    Kiwi 4d
    I have used a 12v hair dryer, yes it works on the drivers side, but dang noisy. Discrete.
    bchctybob and HOTRODPRIMER like this.
  29. BJR
    BJR
    So buy an old under dash heater, like a Tropic Air or Arvin, etc with the defrost ducts and run some ducts under the dash to the windshield. Thats how they did it in the 30's and 40's, so it must be traditional.
  30. Fortunateson
    Fortunateson
    When I was younger and the widows fogged up it meant I was having a hell of a lot of fun!
    Lepus, bchctybob, williebill and 12 others like this.
