Projects 1939 Packard Custom
Discussion in 'Traditional Customs' started by CadMad, Apr 15, 2020.
  1. Hnstray
    Hnstray
    from Quincy, IL
    @CadMad
    It’s got to be very, very satisfying to have accomplished this phase. The entire car is a series of such phases and wonderfully done, each and every one!
    Thank you for sharing the journey.
    Ray
    Outback, Stogy, chryslerfan55 and 7 others like this.
  2. stanlow69
    stanlow69
    Check out the flaps on a 1998 Mercedes. Or around that era.
  3. CadMad
    CadMad
    Yes my daughter has a 2004 CLK. That’s where I got the idea to hinge off the boot from. It’s cable operated. But I have a two stage clearance issue. So I would need to run two cables to each flap. I’ve worked out how to do it but not how to not end up with cables running everywhere.
    For the time being I’ll keep it simple. I’m happy with the spring loaded locks I found. They are secure and easy to operate.
  4. CadMad
    CadMad
    Well this is a nice little solution to locking the ears down. Went to the hardware and found some great little German made, spring loaded, ball bearing locks. $7 for two.
    I’m new to uploading to YouTube so you’ll just have to click on link. https://youtube.com/shorts/_DuM5lYWZl0?feature=share
  5. CadMad
    CadMad
    Dash pieces put back in for a bit of Friday night fun. Still a little bit of tweaking on the centre piece which required rebating into the upper section cos the dash is a completely different shape to the original. Looking for an original headlight switch. Still yet to convert the lhd speedo and clock placement to Rhd. 6DB09E45-6460-4DA4-B71B-0937C8A1A149.jpeg 8F38126A-CD01-4A27-B1E2-D052CB290271.jpeg
  6. patsurf
    patsurf
    prob the only time i've seen the word rebate (rabbet) ever used correctly--almost as many points for that as the incredible work so far..
    Stogy, CadMad and loudbang like this.
  7. Squablow
    Squablow
    That door top really ties the dash end into the door well. Dash looks great, steering wheel is a work of art.
  8. CadMad
    CadMad
    Tidied up a few more details. Swapped over the clock and speedo and got everything to fit a little better. Glove box is operational so that’s a good little job to make a insert. …. After the wiper mechanism is sorted.
    Swapped over my 41 steering wheel to get a feel. Not sure which I like better now.
    Steering column linkage is soon to be on the C557DDDD-9BFC-4453-9D4E-37F068FB24A0.jpeg 5F785755-51F2-4DB7-ABE7-CC0A396E313A.jpeg 4BD90121-08EF-4EF7-9A32-D9A9D0C636A7.jpeg 81D1BB29-473C-4CE0-A131-6ADF88CC1AFD.jpeg agenda.
  9. GirchyGirchy
    GirchyGirchy
    from Central IN
    I vote for the other wheel, the sloping spokes match the feel of the car better than the T-shaped '41.
  10. Squablow
    Squablow
    I agree, the flowing shape of the car and the rounded spokes of that grey pearlescent wheel really work well together. The '41 wheel is pretty on it's own but kinda angular in the cockpit of this car.
    oneratfink57, Sandgroper and WalkerMD like this.
  11. I like the T shaped wheel better. The horizontal section lines up better with the lines in the dash. The angled spokes look droopy to me.
    Stogy, ne'erdowell and chryslerfan55 like this.
  12. stanlow69
    stanlow69
    Droopy matches the contour of the dash top(cowl).
    Sandgroper, loudbang and WalkerMD like this.
  13. Stogy
    Stogy
    Incredible journey your taking us on @CadMad...it truly is awe inspiring...thanks for sharing it with us...
    41 GMC K-18 and loudbang like this.
  14. alchemy
    alchemy
    Here's another vote for the droopy wheel.
  15. Great build..thanks for sharing it with us.
  16. CadMad
    CadMad
    Got the vent flap operating off a 30s Cadillac vent handle. Had to extend the mechanism to suit the stretched cowl. Working in the wipers now. Should be operational by the weekend. EA49D65C-93C5-487F-A08A-AE6CA2A4E25D.jpeg 35CA6568-751C-4B05-A716-0AB5DA813C01.jpeg Works like factory.
  17. ne'erdowell
    ne'erdowell
    This is one of those cars where everywhere you look there is a cool feature, and another, and another...
    Stogy, VANDENPLAS, Hamtown Al and 7 others like this.
  18. CadMad
    CadMad
    Couldn’t find my fedora for X38 so I had to improvise. Mr Foo or Gilligan.
    Rik kindly uploaded it for me.
    Outback, Okie Pete, Randall and 20 others like this.
  19. CadMad
    CadMad
    3B667C49-5AFD-4376-9BF5-7DB4ADEC7374.jpeg 39387CB8-5768-48E2-A046-1DA2D5298E82.jpeg AE5AC290-0F11-473E-9E2A-EB9010F3D8A9.jpeg 0719CF4B-7578-464B-8003-A499D46D04E6.jpeg Sunday job was to finally mate the 39 Buick buckets to 39 Packard rings and 37 Olds lenses and reflectors. Perfect fit.
    Jacksmith, BigO, GordonC and 27 others like this.
  20. Royalshifter
    Royalshifter
    Moderator
  21. nor6304
    nor6304
    from Indiana
    That looks really good
    Stogy and loudbang like this.
  22. Guy Patterson
    Guy Patterson
    I like the one fog light
    Stogy and brEad like this.
  23. ZZ Top Chop
    ZZ Top Chop
    you can't leave us hanging! Any Progress?
    Stogy likes this.
  24. CadMad
    CadMad
    I haven’t done much as I’m in the midst of hectic D7C73930-FA4B-4417-93E0-FEBA277036ED.jpeg work and organising the shipping the remains of a 1 off 53 Eldo from Detroit.
    But I did manage a bit of a reshuffle of the lower dash knobs. These are mid 40s Cadillac from my spare parts stash and are Choke, starter, lighter, ignition and lights in that order.
    brEad, 40two, GordonC and 13 others like this.
  25. Stan Back
    Stan Back
    Hopefully you settled on the "droopie" steering wheel. It also looked like it would be better to see the speedo, too.
    GirchyGirchy and loudbang like this.
  26. Squablow
    Squablow
    The knobs look right at home there. Does the lock cylinder on the driver's side do anything? Or is that just a leftover from the RHD conversion? It kinda looks right there, for symmetry, but I can't imagine what it's function would be.
  27. CadMad
    CadMad
    The knob on the instrument cluster is the dash light dimmer rheostat . I was missing the original knob but I found a nos glove box lock and used the old glovebox lock knob in lieu of the original knob. It’sa little worse for wear but I’ll hopefully find a better replacement shortly.
    This is what I found of the remains of the original dash…. So it was a bit of archaeology.
    I can’t believe a dash could rust away so badly and the switch could be still intact.
    The steering wheel debate will continue as I’m in a quandary. I agree the droopy wheel is more aesthetic but it is a post war wheel, and subsequently the 41 wheel is more in keeping with the period I’m aiming for. By no means is this a period perfect build, but I do like to have a guideline that I try to adhere to. In any event the steering wheel will be the last nut I tighten. So lots of other decisions between now and then. FF637AB8-78B0-4A3B-8889-D5504D661AEB.jpeg E7D05611-9AEC-4C2E-9AFE-355E314E097D.jpeg
  28. ne'erdowell
    ne'erdowell
    Since the steering wheel seems to be open for discussion, I'll add one more opinion. Based entirely on my opinion only I think the original '41 wheel is more pleasing. The "droopy" one is a cool wheel but when you see the wheel in place the curve doesn't balance with the horizontal line of the dash, while the '41 complements that feature nicely. Your mileage may vary.
  29. john W.
    john W.
    LOVE Packards
  30. CadMad
    CadMad
    Had an eBay win. Found a correct for 39 1F71BDA6-1902-4E3E-8047-2CD2EA2D36AF.jpeg heater for $60 that will fit right at home. Coming from a premier Duesenberg restorer in Michigan… can hitch a ride in my 53 Eldo project that is getting shipped out of NJ shortly.
    Stogy, Okie Pete, brEad and 12 others like this.
