Has any one out there used a model A pickup bed on a 1932 Ford PU ?? experiences and a couple of photos would be most appreciated mercryguy
A 31 looks damn close a little shorter and the panel behind the cab curves upward wear a 32 is straight. I'll check the wheel openings and let you know if they're the same next time I'm at the shop.
I have a Model A Box and a 32 pickup box. I'll measure them possibly tomorrow tell me which measurements you want.
A 32 bed is wider by 8 inches and is pretty much a wide bed late 1931 bed. The model a bed is 40 inches wide . My buddy Scott ran a 32 cab with a model A bed and looked good .
There was a 31 A "WIDE bed that carried over to the 32 truck. 33-4 bed front panel was straight across 31-2 had a upward curve.. 31 bed 33-4 bed A bed on a 34 Cold hearted orb That rules the night Removes the colours From our sight Red is gray and Yellow white But we decide Which is right And Which is an Illusion Or in this case what bed looks correct Take the lower metal off from bed.. I think it would look like a big pimple on the end of your nose..
I built a filler panel between the bed and the frame.... If I had it to do over I'd raise it up 2 or 3 inches more..
