Projects 348 powered 40 Ford sedan
Discussion in 'The Hokey Ass Message Board' started by neilswheels, Jul 31, 2014.
  1. neilswheels
    neilswheels
    from England
    Soo, looking at my ‘mini tub’ and talking to a couple of guys running 8’s on the back of their 40’s, I realised it was going to be really tight, and needed more room. Ide been concentrating on making room at the front. I basically made them run further back, as they were tipping in just past the axle centre line. It needs a bit of ‘persuasion’ with a mallet and block of wood, but I got it out of the way and back together.
    loudbang and Kan Kustom like this.
  2. neilswheels
    neilswheels
    from England
    While I was there, I ended up redoing some PO repairs around the bolt holes. They had almost made the wheel fender mount shape octagonal, and to make the fenders fit, added extra bolt holes to pull the fender into the ‘corners’
    I spent ages hammering the fender mount lip out, and replacing half of the fender mount metal, oh, and adding cage nuts to all the holes part of this meant removing some of the inner structure . While it was out, I de rusted the backside of the inner fender, epoxied it, and replaced the structure.
    loudbang, The 39 guy and Kan Kustom like this.
  3. neilswheels
    neilswheels
    from England
    Rust, I really didn’t want to get into this, I thought it was ‘workable’, I’m not building a show car after all, this car won’t be painted, but I just couldn’t leave it. So I decided to fix the base of the b pillar. It’s not in yet, some more rust to sort out behind it, but this little piece took about 6 hours to make and trim to fit.
    Tim, loudbang, The 39 guy and 3 others like this.
  4. neilswheels
    neilswheels
    from England
    Oh, and I finally got my L78’s mounted on my rims so I can work out how much to wack out of the axle.. Small stuff, but all necessary.
  5. joel
    joel
    I'm jealous; I always wanted small window Halibrands for my car. Nice repair on the strut.
    neilswheels and loudbang like this.
  6. Kan Kustom
    Kan Kustom
    Nice work Neil.
  7. The 39 guy
    The 39 guy
    Nice job on the B Pillar feet! Thanks for showing your tooling. Any job worth doing is worth doing well!
  8. neilswheels
    neilswheels
    from England
    Thanks guys, rust is tedious stuff, but has to be done. 39 Guy, if you're doing this, there are some 'mods' needed, if your interested, i can dm you pics etc, thought it might be a bit 'dry' to post all the steps on here.
    The 39 guy, Kan Kustom and loudbang like this.
  9. neilswheels
    neilswheels
    from England
    Had to be done, a quick mock up to boost my morale. Relieved to say that they will fit, with room to spare!
    Both inner rear fenders are now mini tubbed, and I’m just finishing the dull rust repair.
    Nothing that exciting to look at, but all progress
  10. neilswheels
    neilswheels
    from England
    I’ve also picked up a set of 56 f100 rear brakes, early large bearing, so will work perfectly (I hope) with my rear end which will be a 201 quickie with 40 bells, narrowed to fit the halibrands under the fenders and 9 inch shafts.
    Kan Kustom likes this.
  11. Tim
    Tim
    from KCMO
    Nice!
    neilswheels likes this.
  12. Kan Kustom
    Kan Kustom
    Looking good !
  13. Good progress Neil. Keep at it.
  14. alchemy
    alchemy
    The pics of the little-window Halibrands sure brings back memories. About 35 years ago I had a '40 tudor in the same condition (old black paint), and used some shop roller old Halibrands on it. It looked exactly like your mock up.
  15. joel
    joel
    ^^^^^^ Me too. My neighbor had a B/G 53 Chevy with those wheels and I really wanted them for my coupe. He got rid of them and the ' 53 while I was in Uncle Sams Canoe Club. Thanks for the picture; I knew they would look great.
    neilswheels, loudbang and Finn Jensen like this.
  16. neilswheels
    neilswheels
    from England
    Being self employed, work has taken over my free time lately, but I’m plugging away still on the passenger side rear inner fender,
    X38, The 39 guy and loudbang like this.
  17. neilswheels
    neilswheels
    from England
    Ive also finally got a cam for the 348, and dropped that at Dave Gibbons place . He assured me it’s normal for my engine to look like this..
    It’s taken a while to get the cam, beginning of the year was tight for me financially, so no spare cash. When work picked up and I had cash, it then took ages to get Summit to get it in their system so I could order it.
    I ordered a ‘cam kit’ which includes lifters, but it arrived without them. Turns out Isky, who’s cam it is, have a 90 day lead on lifters!? Dave sourced some in the UK tho, so no problem now.
  18. neilswheels
    neilswheels
    from England
    I’ve also been working out my rear end. I managed to get hold of an early f100 rear axle, robbed the brakes and cut the end of the axle tubes off to possibly use on my bells when it’s narrowed.
    I made a ‘thing’ to work out axle width, basically a tube that slides inside another tube with some old drums attached to the end. I slid the tube in until I had the clearance I needed, and that gave me my width. As you can see, it was all very technical with bits of string and weights
  19. Kan Kustom
    Kan Kustom
    Keep going. You will get there. Nice progress and determination.
    loudbang and neilswheels like this.
  20. Keep plugging away. Hey, that's more technical than leaning a couple of squares on the floor, and eyeballing the end of the measuring tape!
    joel, The 39 guy, loudbang and 2 others like this.
  21. neilswheels
    neilswheels
    from England
    And finally, I got a couple of 65 Mustang buckets for it. Really pleased with these, £250 for both, some light wear, but overall great condition. I’ll need to make risers for them so I can see out the windows, but I think these will work great with the look I’m after.
    I was looking at reupholstering the bench, but it would cost a bunch to do, and I’ve been eying up buckets for a while. I can always go back to the bench later if I want.
    Kan Kustom, loudbang and Tim like this.
  22. Neil, what was wrong with the 348 that you had to tear it apart?
  23. Man those wheels stuffed in there is really tough lookin!
  24. Looking good Neil! Those mustang seats look right at home.
  25. neilswheels
    neilswheels
    from England
    Nothing major as it turned out, but with the engine in the car, I just about got it to turn over using a 5 foot breaker bar, so it was super tight. I had all kinds of scenarios running thru my head, but it turned out to be that the pistons had seized on the wrist pins, apparently due to the the lube used during the rebuild going hard. Dave cleaned them out, and its now fine. To be fair, its probably been about 14 years since it was built, so not surprising I guess. Everything else in there looks as good as the day it was done. Seemed rude not to slide a cam in while we're at this stage though
  26. neilswheels
    neilswheels
    from England
    Hows yours going Tom?
  27. I can't believe that it has been 14 yrs since we shipped that across the pond. Time does slip by quickly when your not paying attention!
  28. Slow going as ever Neil, I finally made it steer from the right hand side though!
    ....with that success, I promptly pulled everything from the cabin, front end and engine bay to be tidied up and painted.
    juan motime and loudbang like this.
  29. neilswheels
    neilswheels
    from England
    Yep, necessary, but seems like a big step backwards. I've no front end sheet metal on mine now, no front suspension, engine and box out, rear end out soon and body off the chassis! I hope it goes back together..
  30. neilswheels
    neilswheels
    from England
    5FA9ECA8-3EFA-4D95-B88C-D2E0BB05E5C0.jpeg BE51243B-632A-4409-AA93-7A8F43A88471.jpeg Still here, slowly plugging away. Became very bored with the rear quarter, so decided to finish repairing the front fender captive nuts, which as you can see, escalated somewhat. Dash now out, windscreen out, all rust removed, captive nuts replaced, just about ready for epoxy
