SOLD 1937 cab with 1936 grill and hood, Box is aftermarket hot rod style. Frame is completely custom build with So-Cal dropped straight axle, Speedway Wishbones, Posies front spring and Unisteer rack and pinion steering. So-Cal Buick-type covered Wilwood Brakes. Rear suspension is a 9” Ford with 3.70 gears and parallel Posies leaf springs. Ford brake drums with So-Cal Buick covers too. Rocket Igniter wheels in 16x5 with 750 rears and 6.00 fronts Firestones from Coker. GM crate 350 with Comp Cam 270H cam, FI-Tech fuel injection, Vintage Air front runner system A/C and alternator. Trans is a 4L60E with Hughes controller and Lokar Shifter Large Ford commercial headlights with integrated turn signals. Box has Maple floor with hidden battery box and tool box. Chevy tail lights plus the Vintage STOP light on the rear of the cab. Gas tank from Tanks hidden under floor also. Red leather interior with Classic Instruments Big-Ol-Gauge, Power Windows, Vintage Air heat/ac/defrost unit behind pass side dash, NewPort Engineering Windshield wipers. My dads truck so you can work through me or call him direct -
Time to buy yerself a Hot Rod Pick'em up with all that Christmas Money. Get her to your home for the New Year!!
