New to HAMB
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by busyhornet, Aug 7, 2013.
  1. busyhornet
    busyhornet
    Hello hot rodders!!! I'm new to this. Have 1931 ford with a 1956 corvette engine with factory WCFB CARBS. It has a hydro 4 speed automatic Trans. This was my fathers car he built back in 1956. He built it from the confines of a wheelchair. But I need a little help on the setting up of the hydro shifting linkage. Anybody know about it???? Thanks
  2. hallrods
    hallrods
    Welcome I don't know about the tranny but the car sounds cool. I would love to see some pictures.
  3. willys1
    willys1
    from South Ga
    Welcome from South Ga....any pictures of your car?
  4. busyhornet
    busyhornet
    Hey fellas thanks for the friendship. Yes I do have some photos of the restoration. Stand by and ill send a few..
  5. busyhornet
    busyhornet
  6. busyhornet
    busyhornet
    ImageUploadedByH.A.M.B.1377994004.322447.jpg my fathers hot rod restoration under way. 1932 ford frame, body channeled over frame. 1956 corvette engine with a four speed hydro Transmission.
  7. busyhornet
    busyhornet
  8. busyhornet
    busyhornet
    ImageUploadedByH.A.M.B.1377994431.343224.jpg my dad working on the car around 1984 1985 changing head gaskets.
  9. busyhornet
    busyhornet
    Ill get some more pics very soon of him driving the car in the 1950's. he also drag raced the car in halls Tennessee at the old WWII army air corps base.
  10. busyhornet
    busyhornet
    The scallops don't look too good and straight, I painted them real quick to see if I wanted to put them on.
  11. Welcome from CT! Very Cool
  12. Nice pics. Welcome from Mississippi
  13. post the hydro questions on the main board there are a couple guys that are still up to speed on them
  14. busyhornet
    busyhornet
    Thanks fellas.. This car was built and driven & raced on the the streets of Memphis Tennessee.
  15. busyhornet
    busyhornet
    Eugene, thanks ill try that.
  16. busyhornet
    busyhornet
  17. jimmy six
    jimmy six
    As “cool” as it sounds if you can get it to work fine but I wouldn’t spend much or any money of one of the old hydramatics. A modern trans will save a lot of weight and major problems on the road. Last time I had one worked on I had to supply a second one.
    As for linkage the hydramatic, the pressure arm/link pulls back the same as the throttle. DO NOT connect it on the bottom hole on most carbs, including the Carter WCFB, I drilled a hole about 1/2 “‘under the main large hole on the carb linkage the last time I used one. Good luck and have fun with the coupe..
