Technical Risers on flathead ford carburetor’s
Discussion in 'Traditional Hot Rods' started by robert graves, May 31, 2021.
  1. robert graves
    robert graves
    Will putting 4” risers under Holley 94 carburetors affect starting or performance of a flathead ford 59a engine , 3/4 race cam set up .060 overbore Navarro heads and crab style distributor , intake is a offenhauser dual carburetor style
  2. tubman
    tubman
    Just curious; what kind of dual manifold? "Super" (carbs directly over the two sets of intake ports, "Regular" (carbs evenly spaced but closer together, or "Biased" (front carb in almost the stock location with the other behind it. Also, are you planning on running straight or progressive linkage?
  3. robert graves
    robert graves
    I’ve got progressive linkage and evenly spaced carburetors
  4. chevyfordman
    chevyfordman
    Would you believe that my 40 has a plastic riser and it actually runs so cool that moisture condenses on the carb base but no problems. 452AAA7D-2F33-4D36-9540-90EB7A1EEE29.jpeg
    loudbang and robert graves like this.
  5. tubman
    tubman
    Just my opinion, but I don't think this is a good combination. You will have very uneven fuel distribution. In just about all cases, dual carbs run best with straight linkage. The only way I would attempt to run progressive with dual carbs would be with a "Biased" manifold with the front carb as the primary.
  6. flatmotor40
    flatmotor40
    from georgia
    I made 2 on mine to keep carbs from boiling after running.Had 94's but later put 97's.No more boiling
    dirty old man likes this.
  7. alchemy
    alchemy
    I don't have added risers, but I have a tall intake. Mine runs just fine, but I wouldn't say it runs better than a regular short manifold. Sometimes I can feel ice cold on the carb bases and top runners of the intake. Mine has straight linkage.
    patmanta likes this.
