Hot Rods Blower manifold carb adapter plate
Discussion in 'The Hokey Ass Message Board' started by tk2leadsled, May 9, 2021.
  1. tk2leadsled
    tk2leadsled
    from Manor, TX
  2. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Nope,but, That dose not have a blowback valve*/backfire,so would have too make one,as for flow in mild engine, blower just pushs passed every thing.
  3. squirrel
    I think you have the idea upside down....???? This part goes onto a blower manifold, in place of the blower.
    Never tried one, I put a normal intake on when removing the blower. That part seems rather silly to me. But what do I know.
  4. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Jim,,Maybe,I didn't look enough at the add!,Though was too put a blower on a 2x4 intake? From pic.
  5. Bob Lowry
    Bob Lowry
    Keep in mind that most blower motors are only 7.5 to 8.0 compression, so if you went
    to a carb setup, they definitely would be doggy....
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What Jim said. What a waste of money not to mention, a blown engine is built to operate with a blower, not normally aspirated.
    Deuces, Blues4U and loudbang like this.
  7. seb fontana
    seb fontana
    from ct
    Defiantly single plane.. Marketing..
    Deuces and loudbang like this.
  8. Never2old
    Never2old
    from so cal
    I made one so that I can fire up and run the engine and get the timing set right without boost.
  9. 19Eddy30
    19Eddy30
    from VA
    You will be surprised what works and what does not !!
    Each engine combo is different,
    the only way you will know is to Dyno, TEST &TEST!!!
    most will build a engine Put on a Dyno
    & tune for those parts used ,
    If yr Serious ( About yr thinking )what works , you will have a shop full of parts , Test test & notes & Divorced, the Dyno is one part , then you move to Test & Test to what the power plant will be going into. & You still might end up with a combo that Not compatible.
    Deuces likes this.
  10. flamedabone
    flamedabone
    That is like cutting an inch off your ....
    -Abone.
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    What????
  12. That thing is kinda goofy, no wait, it is goofy !
    A blower intake is around $450 bucks, plus the price of that contraption would be twice the price of a 2x4 intake.
  13. Never2old
    Never2old
    from so cal
    It cost me 3 hours work and some scrap aluminum.
    I have an electronic conversion in the Mallory distributor so I have no faith that I can static time it.
  14. tk2leadsled
    tk2leadsled
    from Manor, TX
    S
    So did ya ever get drive it with that setup ? Just curious if it would be extra rich.
    Thanks for the reply
    Thomas
    Deuces likes this.
  15. Never2old
    Never2old
    from so cal
    I'm still waiting for my engine run stand to fire it..
    dana barlow likes this.
  16. seb fontana
    seb fontana
    from ct
    Why can't it be cranked with the starter with timing light hooked up for static starting place?
