I see 2 options... Slip the 5AN hose over the 5/16 hard line and clamp it. Or Flare the tube an use a male or female 1/2" x 20 Inverted Flare, and a fitting on the AN hose. My preference would be to slip it over the tube and clamp it. I cannot find a "cheap" bead tool for 5/16 tube though and without a bead it feels loose. So is there one AN hose end that can get me tied in without using an adapter, and a bunch of connections?
I don't know everything but I've never seen no. 5 an hose. It's all even numbered. -6-8-10, etc. If you are using number 6, that is 3/8" hose.
https://www.holley.com/products/plumbing_an_fittings_and_hose/hose/auto_flex/parts/300005ERL It is just multiples of 16.. 5 is 5/16 6 is 6/16 or 3/8 8 is 8/16 or 1/2
AN fittings are just hydraulic JIC fittings, go to a hydraulic hose house they will have fitting that will work. you can do it like this but a jic flare is 37* not the standard 45* that brake and fuel lines are. you can also get a compression fitting to jic end. like brooks said “easy peasy japonesey
The adaptor is not what I’m showing but the fitting that will fit on a flared line and accept a male an fitting. Sorry should have been more clear.
If you have a cheap double flare tool you can just do the first step to put a bubble on the steel line.
Terminate the hard line in a 37 degree single flare with backer and nut. Terminate hose with an AN to tube fitting. It's a hose end fitting with a male flare. Screw together.
Didn't intend to come off as a wise guy. You were looking for easy! I also posted on your other thread.
No no no, you didn't, I was joking. But After I read what you you wrote...I was thinking that should have been obvious. Thanks for the post in the other thread...I need to pick up one of those gauges. I am ordering a flaring tool and was trying to figure out which set of dies I needed with it. Ok last question for you. I would prefer to run 3/8 hard line over the 5/16. The problem with that is the nipple on the fuel pump is for 5/16 and moulded into the housing. Is there anyway to get from the 5/16 hose (I'd like a short piece of braided) to the 3/8" tube?
If it was the first picture you posted you could pull out the tube and tap the boss like the outlet. The second one doesn't have much to work with. If it wasn't crimped together you would have some options to modify the connection but it would involve heat. I would look for a different if you can.
I guess if you have to use pump #2, and you are using a push on hose, you terminate the 3/8" hard line with a flare and use a male flare push lock fitting on one end of the rubber. The easy fix is use 5/16" rubber hose and have no need to modify the pump. You could use 3/8" hose and build up or expand the pump tube slightly.
The nipple is for the flex line from the tank. Do you really need to convert that to AN, or JIC? Just asking.
Like AngleD said.... Use the first stage of a double flare.... makes a very good bubble for clamping a hose to.... LynnW
Cut the bubble off the pump and use this? Not sure you have enough room. This is how I transition hard line to flex.
I once used a compression fitting from my local hydraulics shop so I could convert a hard line on an IROC-Z power steering box to AN-6. I have also used silver solder to add AN fittings to steel lines, and even TIG welded some stainless fittings together to get what I needed.
The cleanest way by far! Get yourself a male pipe to JIC adapter, put it in the lathe and drill for slip fit to the tube, and turn the pipe threads off to make a nice sleeve for attachment to the tube. A little heat and silver solder will produce a factory looking tube end that will out live us all.
There's some oddball sizes here 3/8's to -6 5/16's to -6 etc https://www.redhorseperformance.com...COA2Jyci87zk6M-xk9WGDgr8LOTCWJqsaAl4VEALw_wcB .
Not HAMB friendly, however it depends on pressure, SS Compression (Swedgelock) fitting with an adapter to braided fuel line. or a bulb on hard line with hose and clamp (Vacuum line) For brake lines, braided hose with AN fittings, through frame and banjo. I'm doing my 6x2 cross ram the same as #22
The slickest way (I think) would have hose barb put on the hard line, put the hose on it with a ferrule and have it crimped by someone with a set of AC line dies. Pretty much permanent but would look nice. Gary
What is the origin of the hardline? They make male inverted flare to male jic fittings. I have put them in automatic transmission to cooler and brake proportioning valve. They do make -5 JIC flare less connectors that work just like compression fittings. It will be a tube nut and ferrule so that will go to male jic from to hard line but no step. Hydraulic shop will be able to get them. Sent from my iPhone using The H.A.M.B. mobile app
This connection is on the suction side of the pump? I'm curious why you're connecting AN hose to it, in the first place....
